We have a Case 480F LL (has a 3 point and a hydraulic driven PTO instead of a backhoe), we have a small farm and use it for moving dirt, stacking hay bales and running the round baler.
After running the round baler (a Ford 552 that we have run with a 38HP Kubota, the Kubota was marginal on HP, but it ran it) for 20-30 minutes, it starts slowing down when under load, the PTO tach says 300-400RPM rather than 540-600 with the engine running wide open and it will stall if you push too much hay through it and I can hear the pressure relief bypassing (but I have only noticed it bypassing loudly when its stalled, if its bypassing otherwise when hot, it doesn't make enough noise to hear it over everything else).
When this happens, the hard lines going to/from the valve block are hot enough that they are uncomfortable to touch, but not to the point where it hurts or burns you.
Not sure what pressures are, I haven't had a chance to tee in a pressure gauge yet.
Is this behavior to be expected from a hydraulic PTO, or is something likely wrong with it?
Other than this, its a great machine, always starts right up, plenty of power, pushes/pulls hard (even when its hot and the PTO is weak it loads down the engine if you accidentally put it into gear with the parking brake on
), stacks 4x5 round hay bales with a spear chained to the bucket like they aren't even there.
Thanks
Aaron Z
Thanks
Aaron Z
