is the pump disassembly and reassembly as staraight forward as it seems?
1) - there are three bolts hold ing the pump on. I should scribe or mark the pump housing in some way before taking off the engine. do this before taking three bolts out.
2) - there is two seals that face away from each other that goes on the shaft that stays with the engine, is there any special installation for these seals?
3) - then for pump installation i have to line the dots up on the end of the shaft with the dot inside the pump to get timing correct.
4) - any tips for getting the pump over the new seals i pump on the shaft??
5) - after that i bolt the pump back on lining up with the mark made from earlier.
1) You will need a 9/16" startermotor/halfmoon spanner for the rear mounting nut & depending on the spanner make you will need to grind the ring on one half as it will not have enough clearance between spanner & pump housing.
re scribing - ideally you need to check timing, but if you remove the thin rectangular cover held on with 2 screws on the side of the pump, you will see timing markers. Before you remove the pump, rotate the engine till these line up; remove the pump; do not rotate engine; when installing - align the marks.
2) The seals just stretch over the end of the shaft
3) Yes line up the 2 dots on the end of the shaft - if you don't the timing marks metioned in #1 will not align ( 180 deg out)
4) There is a tool. But it can be done easliy using fingers. Lube the seals (I use Vasolene) & gently move the pump onto the first seal, tucking in the lip with your fingers.
Often as the pump is about halfway onto the first seal - withdraw the pump a little, & then back on - it seems to help....
5) align the marks in #1 & "Bob's your Uncle"
** Do not remove the driveshaft with the pump - just undo the three mounting nuts & slide the pump off the shaft.**
I usually remove the fuel filters & housing & the exhaust manifold to allow easy access to the injector lines - some guys leave the manifold on - please yourself.
