Case450-1975
Recently purchased a 1975 Case 450 dozer that had been sitting for 8 + years. Decided to change all filters and fluids along with some other maintenance work it required. Getting filters at an economical price has proved challenging but had luck so far.
When I pulled the hose and cover off the suction filter ahead of the hydraulic charge pump it was full of aluminum shavings. Where would the be coming from? The charge pump itself (even though the filter was stopping them from entering the intake). Could it have the aluminum pistons in the clutch packs?
I will check the hydraulic reservoir as well although the fluid in it appeared clear when I drained it.
Any help/suggestions appreciated.
