Tinkerer
So tinkerer ! Here’s what came out of my transmission on the third drain . I filtered all the oil just like you said . I also drained my oil and a very small amount of mud came out of that also . Then I rinsed it with diesel and blew air in there and a small amount flushed out again . It seems like it’s clean now but I wanted to drop the oil pan and can’t figure out why it seems to tuck in under a separate divider into the torque converter . Don’t know how I would get to those nuts . Hard to explain , I should have taken a picture . I’m going to put 15/40 in it instead of 30 w . Glad I drained it though . Never would have thought mud got in there also .
Just to clarify-->You flushed the engine and you are taking the oil pan off of the engine, correct ?
Did you start the motor and run the transmission in gear to get the oil warm when you did the hydraulic flush ?
Is that crap water soluble ?
I know it saturated with oil. Burn some of it and see if whats left looks like dirt.
