Tinkerer
Have you checked the final drives for mud ?
Have you removed the belly pans and looked for damage to the transmission
case ?
case ?
Yes , no mud in the final drive and yes I have removed the belly pan and there is no damage anywhere .Have you checked the final drives for mud ?
case ?
I could if I knew how but I don’t but I can tell you that if I pour oil into the suction line with no room for air the system will charge . They’re going to return the charge pump I just purchased because I think it got weak and failed but I’m really reluctant to try the new one without knowing the system is clean .At least the final drive seals are OK.
Must be extremely frustrating.
That crap may have been sucked in somewhere.
Can you seal up the system so you could pressurize it with air to find a leak ?
If the suction filter didn't rupture the system beyond it should be clean.I know I’ve said this before but I think it’s caught up in the torque converter . Or the bottom of the tranny . Remember, there’s not clumps or anything like that but after three flushes you can still see small signs of it.
well , i dont know what you mean by rupture , both filters sowed signs of mud . the first flush worse than the third but still evident ,.the tranny oil was running very hot in my opinion when the the new pump shut down . i actually took the new pump apart and saw no sign of dirt . something is restricting the flow and im wondering if someone could tell me if it could be in the converter .If the suction filter didn't rupture the system beyond it should be clean.
If the suction filter did pass crap then only the pump could be damaged.
The pressure side filter should have prevented fouling the rest of the system.
its defiantly not in the suction line . if i use a small wet vac on the suction line the oil comes right up , no problemwell , i dont know what you mean by rupture , both filters sowed signs of mud . the first flush worse than the third but still evident ,.the tranny oil was running very hot in my opinion when the the new pump shut down . i actually took the new pump apart and saw no sign of dirt . something is restricting the flow and im wondering if someone could tell me if it could be in the converter .
The radiator cooling lines have been blown down . I never actually watched the flow because the pump was never working right . The only thing I noticed after I installed the new pump that worked good for about an hour was the oil pressure was low . It should be a constant 40 and it was 30 and went down to 20 . Can’t figure that one out either . I am going to change the filter . The engine runs perfect . No smokeSorry, Mike.
Rupture means a a hole blown open in it.
Perhaps the cooler in the radiator is plugged. Disconnect the RH hose from the bottom of the radiator (the oil cooler) and see if there is a good flow of oil coming out.
Or the charge pump has problems.
Was the engine laboring in neutral when the oil got hot ?
I’ll probably end up bringing it to case . It’s going to cost me a lot but at least I don’t keep fishing . Most of the time things are fairly easy to figure out but this ones a combination of things and I don’t think I’ll ever figure it out . Sucks !Sorry, Mike.
There’s only so many things it could be . I don’t why but I keep leaning towards the torque converter . I think it’s got mud in itSorry, Mike.
Yeah , I got that . Used it to rebuild the old pump but it still didn’t work . Thank you though !You would need to remove the transmission breather and replace it with a pipe fitting so that you can apply regulated air at about 10 PSI. Unless it all leaks out around the gear shift lever.
You probably already have this info for the new charge pump installation.
If you don't here ya go !
Pay particular attention to the position of the gear in step #7 and the cotter pin install.
So tinkerer ! Here’s what came out of my transmission on the third drain . I filtered all the oil just like you said . I also drained my oil and a very small amount of mud came out of that also . Then I rinsed it with diesel and blew air in there and a small amount flushed out again . It seems like it’s clean now but I wanted to drop the oil pan and can’t figure out why it seems to tuck in under a separate divider into the torque converter . Don’t know how I would get to those nuts . Hard to explain , I should have taken a picture . I’m going to put 15/40 in it instead of 30 w . Glad I drained it though . Never would have thought mud got in there also .You would need to remove the transmission breather and replace it with a pipe fitting so that you can apply regulated air at about 10 PSI. Unless it all leaks out around the gear shift lever.
That’s mud , hard to tell from the picture . Now that I look at the picture kinda looks like a female counter part . Lol ! Sorry , it does though ! LolView attachment 220045
also badly maintained[QUOTE="minda looks like a female counter part . Lol ! Sorry , it does though ! Lol
