Case 440ct Pattern Change
fencefool
California
Asking around out there if you can change the pattern on a Case 440ct series 3 from ISO to H pattern. I didn't know if there are certain hydraulic pressures associated with each function or if there is a valve block where the hydraulic service lines from joysticks can be switched to accommodate the H Psttern.
KSSS
Idaho
excavation
They used to sell the kit that changes the pattern at the dealer. I don't know if that is still available or not.
GaryHoff
Alberta, Canada
Heavey Equipment Mechanic
Unfortunately hydraulic lines can't just be swapped around to change the joystick pattern. As KSSS mentioned, you will need a kit from the dealer.
Txhayseed
Texas
H pattern... Kicken it old school.. You do have to buy a kit.. And then... And then... The fun of installing it.. As the cool aid man says.. Oh yeah
KSSS
Idaho
excavation
H Pattern..........still the best way to run a skid steer! At least for me.
