soapstoneguy
I have a case 40xt. I replaced the battery this past spring and back in June had a little problem when I put the key in and went to turn it over it just clicked (clicking sound back by the starter) I turned it off, stomped my foot on the floormat (where the batter is, there is a little gap between the floormat and the battery itself so I wasn't stomping directly on the battery) and it fired right up. Haven't had any problems with the machine then all of a sudden the other day when i turn the key i get nothing...just some clicking (which sounded like it was coming from the starter) so I checked my battery, had it tested and checked out. Pulled the starter off and had it rebuilt but after installing I just got the same result. I did notice that the key is a bit sloppy in the ignition so I'm wondering if it is a problem in there. I don't know if the cold weather has anything to do with it or just the temperature change in general...
Any help would be appreciated!
Thanks guys!
Thanks guys!
