soapstoneguy
Hey guys,
So I'm pretty sure the hose that is leaking is the one that controls my bucket tilting forward and backward. I pull the cab forward to look underneath and hydro oil all over the place. I believe I found the culprit which is (if you are sitting in the seat on your left side underneath you) a hose that is attached to a bracket (to keep it straight) which is bolted to the machine itself. When I pull the bolt out to free the bracket hydro oil starts coming out of the bolt hole, not a lot but just a little trickle. Underneath the bracket are two nuts that tighten down around the bracket to keep the hose straight. I loosened those to get the bracket out of the way. There is a good sized rubber bladder looking thing that that hose feeds in to...I can slide the hose out of the rubber bladder (which i believe is where the leak is) and when I do so there is a cable that is inside the rubber bladder that is connected to the hose. Keep in mind this hose is only about the circumference of a pinky finger. Anyway, I don't know what the heck it is as I've never seen a hydraulic hose with a cable in it like that. It feeds right into the side of the machine, I'm guessing into the hydraulic tank somewhere. When I use the controls (machine off of course) I can see the hose move and the cable goes in and out so I'm guessing it has a valve in there or something which controls the hydro oil flowing in and out etc...not sure.
Hope someone can help!
