CASE 1845c Restoration. Follow my progress!
Discussion in 'Skid Steers' started by Larpy, Feb 13, 2019.
  1. Larpy
    Larpy Well-Known Member
    Jan 29, 2019
    147
    Denver
    I will post pics of this project as I progress. I needed something to keep me busy. I found something!
    Joel59 likes this.
  2. Larpy
    Jan 29, 2019
    147
    Denver
    The before pics.
  3. Larpy
    Jan 29, 2019
    147
    Denver
    Cab off
  4. Larpy
    Jan 29, 2019
    147
    Denver
    I have spent a lot of time cleaning. The well under the seat was packed with mud, fluid and trash! I separated the top part of the cab from the lower section. All the controls have been disassembled and new bushings, rod ends and fittings will be installed after sand blasting this weekend! I am painting this unit military tan with a high end enamel used by Lockheed Martin's space program (Long story on how I got it :) )
  5. 74inchShovel
    74inchShovel Well-Known Member
    Jan 19, 2008
    156
    Washington
    Great platform to start with. (Simple, rugged and dependable) Funny how those three go hand in hand. Best engine ever put in a skiddy, imho. Known to go 10k+ hours before rebuilding. Made by a major company for many years, parts should be no problem. Looking forward to watching your progress !
  6. thepumpguysc
    thepumpguysc Senior Member
    Mar 18, 2010
    6,179
    Master Inj.Pump rebuilder
    Sunny South Carolina
    I guess it stands to reason that u wouldn't have started this project w/o sufficient info before hand..
    BUT just in case.. e-backhoeparts dot com is where a lot of guys go for info & parts..
    Dale Weiss is a walking engine manual, when it comes to just about anything Case.
    Good luck w/ your project..
    Tenwheeler likes this.
  7. Vetech63
    Vetech63 Senior Member
    Aug 10, 2016
    4,398
    Oklahoma
    < waiting on Tracings "Dale the cat.":D
  8. Larpy
    Jan 29, 2019
    147
    Denver
    Thanks for the info! I have been studying the Service manual and parts and have done well so. Most items I have needed have been located so far. I wish there was a salvage yard here in Denver but no luck that I have found. Off to the bead blaster this morning for the hand controls and linkage assembly for the controls.
  9. Larpy
    Jan 29, 2019
    147
    Denver
    I have spent a lot of time cleaning this 1845C up. A lot of pressure washing and degreasing. I started the sanding and prepping after deciding not to sandblast the frame. It was less of a mess to sand.
    Marco Salcedo likes this.
  10. Larpy
    Jan 29, 2019
    147
    Denver
    I disassembled the hand controls and prepped the ROPS frame. The cab was removed last week and is being sand blasted. The frame is in good shape but it needs a refresh. Lots of work but I get bored! It helps when your best buddy owns a body shop. Nobody is around on the weekends and evenings!
  11. kshansen
    kshansen Senior Member
    Mar 11, 2012
    10,010
    Central New York, USA
    I know you said you were going to be using this machine at a high altitude but do you really need paint spec'd for a Mars Rover?
    Forget, is this the Case that had the problem with the park brake lock pins or was that some other guy?
    To be honest,I did not really like the 1845C when we got the new one at the quarry back in March of 1989, I felt the steering was not as smooth as the older 1845 skid's I was familiar with at the time. That said when I retired in April of 2015 that was one of the few machines I would have liked to have taken home as a retirement gift. No luck! Boss said they still needed it!:(
    Two things I want to see from this project. First a glamour shot once it is all back together nice clean and shinny. Second a shot of it hard at work up in the mountains.
  12. phil314
    phil314 Senior Member
    Dec 28, 2014
    277
    Instigator of Choas
    Otsego, Mn
    Great work so far. I bet it will look awesome when you are done.
    I've always thought the one great addition to an 1845c would be a full set of real gauges.
    Since you're going to all this work, why not fab up a panel and wire in some gauges to monitor the engine and hydraulics better.
    There was a thread a while ago from a guy who did something similar.
    Found it:
    https://www.heavyequipmentforums.co...ngine-tmd20-vs-v2203.30130/page-2#post-446442
    Larpy likes this.
  13. Jeepwalker
    Jeepwalker Senior Member
    Aug 12, 2011
    284
    If your engine cover is as sloppy as most, now would be a good time to weld in another support, before you paint it ...re-do the door hinge right, like Case should have. Seems like they all sort of hang off at a cockeyed angle.
    Here's another tip: you could remove a bunch of normally plated parts (like the lines, fittings, bolts, etc) that might be rusty or gray and old-looking, and send them to a cad plater. Probably get everything chemically stripped and re-plated like new for $150. Not sure if you want to go that route. I put a pile of Corvette parts and bolts together once. One pile to be yellow cad plated, the other silver cad plated. They did them all and it was like $50 for each pile. Came back looking like new!
    Nice work BTW. (click below for pics) Sorry I couldn't get them to show
    [​IMG][​IMG]
    [​IMG]
    [​IMG]
    Marco Salcedo and Tenwheeler like this.
  14. Larpy
    Jan 29, 2019
    147
    Denver
    The paint or epoxy was purchased for a capsule but the specs were later changed and two gallons of extremely expensive product was left. We have had to send it out to be tinted by the manufacturer which takes a few weeks.
    My 1845C has all the parking brake parts so I am lucky. The previous owner unhooked all of it though. It am going to get it working again! I will definitely post some after pics!
  15. Larpy
    Jan 29, 2019
    147
    Denver
    I have had the flu so my progress has slowed but I was able to locate an enclosed cab setup for my skidsteer! Super excited about that because it gets cold at 10,400 feet! I also spent some time disassembling the hand controls for media blasting which I will do tomorrow.
  16. phil314
    Dec 28, 2014
    277
    Instigator of Choas
    Otsego, Mn
    Take lots of pictures as you take things apart.
    Taking it apart is always easier than putting it all back together.
  17. Dmoneyallstar
    Dmoneyallstar Well-Known Member
    Jul 13, 2018
    47
    Toledo, Ohio
    Wow, that thing looked pretty clean on the inside in your "before" pics -- definitely cleaner than mine. Hardly any rust in yours. Looks like it was stored indoors for most of its life.
  18. demetrios007
    demetrios007 Member
    Mar 21, 2006
    10
    NewJersey
    My best friend owns a body shop too and I restored my 751F like u are. I started sanding but eventually blasted it all. I have 110 hours in mine w repairs and paint but was worth it. I used PPG epoxy primer over PPG fleet 2 part for finish. Like a brand new machine the decals are icing on the cake. Good luck w it I feel your pain and pleasure. Looks great so far
    3X8 likes this.
  19. Larpy
    Jan 29, 2019
    147
    Denver
    My brother's untimely death and estate settlement has slowed my progress but I do progress. 7 plus hours of media blasting on the ROPS and base along with the linkage to the hand controls is done and painted.
    I removed the lift arm and will soon media blast it. Having the right equipment helps! The fork lift is a huge benefit!
    phil314 and 3X8 like this.
  20. sims
    sims Well-Known Member
    Jun 1, 2008
    110
    Rutledge, GA
    Larpy;
    Do I see a weld bead across your lift arm? If so, you might want to "fish plate" that repair to prevent it from breaking again. Butt welding a crack in a high stress application is not the best repair. Keep up the good work. Your restoration is looking great.
    SimS
