Case 1840 pins & bushings
Discussion in 'Skid Steers' started by Mark1840, Jun 29, 2020.
  1. Mark1840
    Mark1840 New Member
    Jun 29, 2020
    1
    Michigan
    I purchased my first skid steer I noticed when I stepped on the bucket it would rock and that the pins seems sloppy in the quick disconnect I remove the pins from the cylinder ends however the bottom pins that goes through the lift arms seemed way too sloppy like they're missing the bushings or something they're not egg-shaped either. Any help would be great thanks 20200628_195422.jpg 20200628_195419.jpg 20200628_195422.jpg
  2. bad Tom
    bad Tom Member
    May 7, 2020
    5
    Effingham Kansas
    Sure looks like the bushings are gone. I checked the parts books and Case does not show any bushings, that is strange. The book shows the pins to be inch thick. You might measure the bores and maybe get some bushings at a parts store or check with your local Case dealer and have them call the company to get some information.
  3. Theweldor
    Theweldor Senior Member
    Feb 17, 2018
    471
    Western, NY
    If those are standard sizes.? Look into inner needle bearing bushings. Relatively inexpensive and would serve that purpose well.
  4. Tinkerer
    Tinkerer Senior Member
    May 21, 2009
    4,856
    On A Riverbank in IL. USA
    It looks like the cylinder needs a new rod eye and bushings. :(
  5. bad Tom
    bad Tom Member
    May 7, 2020
    5
    Effingham Kansas
    The rod end of the tilt cylinders on a 400 series have two bushings on the rod. One on each side of the grease zert.
    apetad likes this.
  6. kshansen
    kshansen Senior Member
    Mar 11, 2012
    8,168
    Central New York, USA
    I have to wonder how bad the rest of the machine is if they let the pins/bushing get that worn!
    The chance you can find a bushing that will really fit tight in a worn hole like that is very slim. Trying hard not to sound too negative but.....
    Any chance there is a shop near by that does line boring? It might be possible to bore those holes out to where they are round again and then have sleeves made to bring them back to size for standard bushings.
    I know you don't want to hear it but next time you need to inspect a machine close before buying it.
    All that said if this is going to be a machine that only sees limited use cleaning up around the barn you could just measure the holes and find some steel bar stock that fits closer than the present pins and live with the slop.
  7. Tinkerer
    May 21, 2009
    4,856
    Or, you could repair the cylinder rods and weld the correct pin to the frame.
    That is an extreme solution but cheap.
    kshansen likes this.
  8. apetad
    apetad Senior Member
    Jul 25, 2012
    320
    Compact Construction Equipment Sales
    Leander, Texas
    1840 is the same, don't have part number handy though, replaced 100's, youl'd think I'd remember
