Rick@Woodlawn
Hello, looking for some experience here. We have a Case 1825 w/gas motor. The Charge pressure light/alarm is staying on much longer than normal when cold starting the unit. Once it warms long enough (several minutes) to go off and drive is active it runs fine. The normal warm time even in cold weather 0-20 deg F, is usually only a minute or two. If you move it too soon it will lock the drive for several minutes. We've had it for several years, doesn't see heavy use and seems to only act this way in cold weather. Thanks in advance for any help.
Rick
Rick
