Carolina Attachments brush cutter
Discussion in 'Construction Equipment Attachments' started by 69zfarmer, Mar 23, 2020.
  1. 69zfarmer
    69zfarmer Well-Known Member
    Feb 1, 2006
    147
    North Alabama
    I just bought a extreme duty 72" CA brushcutter. It has the 3 blades sandwiched between 2- 3/8" thick plates. It is built heavy enough but the bolts that hold the 3 blades are actually welded to the bottom blade carrier. The nuts that hold the bolts are locked down in a hex on top blade carrier and cannot be turned.
    The only way to get the bolts out is to take a cut off wheel and cut the welds off and then turn bolts out. I dont like this design. The blades are made to cut in either direction without turning them over. The Radial Piston hydraulic motor will not reverse. It has a case drain. Are these style motors designed to reverse directions? I even tried to swap the hydraulic hoses with no luck.
      File size:
      72.3 KB
      16
      File size:
      51 KB
      17
      File size:
      65.8 KB
      17
      File size:
      55.8 KB
      17
  2. Tones
    Tones Senior Member
    Mar 15, 2009
    1,226
    land clearing contractor
    Ubique
    In the first pic it shows the hoses connected by what could a pressure relief valve so oil won't flow in reverse if you changed at the machine. Try changing the hoses on the motor and see if that works.
  3. Tones
    Tones Senior Member
    Mar 15, 2009
    1,226
    Ubique
    Any luck???????????????????????
  4. 69zfarmer
    Feb 1, 2006
    147
    North Alabama
    You are probably right. I called the factory and that is what they told me to reverse lines at motor. I have not tried it yet. Only problem is when I reverse it the mulching teeth between the blades will be pointing the wrong way. I will reverse it at some point since the blades are gonna be such a job to remove.
  5. Mark13
    Mark13 Well-Known Member
    Feb 28, 2013
    211
    IL
    My CID cutter is the same way, when I changed blades I cut the welds off around the heads of the bolts and then backed them out with an impact.
    To change the direction of the cutter I flip the hoses and the pressure relief right before the hyd motor on the cutter.
