Care required using gas axe
Discussion in 'Safety Issues' started by Nige, Oct 21, 2018.
  1. Truck Shop
    Truck Shop Senior Member
    Dec 8, 2015
    6,205
    star gazer
    SE Washington St
    The first thing when heating u-joints is to remove the zerks and stand to the side. Also the use of heat temp paint stick helps prevent over heating of parts.
    But the other killer that is not mentioned in this thread is the improper use of a press. When pressing bearings a scatter shield is a must-no if's, and's, or but's about it.
    Think of it this way-a 1/2" ball bearing is a 50 caliber round and can go through three walls at the blink of a eye. I was in a auto parts/machine shop store years ago
    buying some brake shoes for my pickup when an incident like this happened. The ball bearing just missed the sectaries head in her office after it already had passed
    through two walls one being the restroom. The ball was finally stopped by a 2 X 4 stud in the wall of her office. No joke presses are deadly as hell.
  2. DMiller
    DMiller Senior Member
    Feb 22, 2010
    10,308
    Almost Retired
    Have run presses most of my adult life, ALWAYS some form of shield on the press or the materials being pressed. Actually saw a Hendrickson beam fail installing bronze bushing, the kid doing it THOUGHT or failed to that the beam would square up as it was shoved in. Chunk the size of a average dirt clod scattered across the shop.
  3. 92U 3406
    92U 3406 Senior Member
    Jan 3, 2017
    1,728
    North of there but east of here
  4. Truck Shop
    Dec 8, 2015
    6,205
    star gazer
    SE Washington St
    Good vid 92U
    Mother Deuce and DMiller like this.
  5. sandy
    sandy Well-Known Member
    Aug 16, 2007
    56
    diesel mechanic
    Had one a couple of weeks ago
    in field repair
    Dana front axle on deere tractor
    tie rod had snapped off at the joint., ball seized in with rust
    heating up as locktighted threads in end of joint where screws into steering ram
    noticed one side off joint starting to swell, stepped back
    joint swelled some more then blew a small hole in the side
    and a fine jet of flame approx two foot long shot out.
    made a loud bang and had to sit down awhile
    is fairly common to have to heat the end to burn the locktight to get them off
    usually the joint is worn and sloppy and you do get a bit of smoke
    I think in this case as the joint was seized with rust pressure built up at the back
    until it blew a hole through the side
  6. jeff112
    jeff112 Well-Known Member
    Jan 12, 2011
    97
    michigan
    Another area that is often heated to free a component, Would include a brake caliper bracket slider pin. That often tends to rust and stick. I have over heated per say in attempt to free stuck pin to have experience the separation occur in a split second! Like a rocket!!!
    Nige, DMiller and funwithfuel like this.
  7. Nige
    Nige Senior Member
    17,796
    I suspect that is also what happened to the joint that was the start of this thread. That was also a Dana axle. I’ll be honest WTF was my first thought when I saw the joint after it let go. Like you I always imagined that a worn one could not seal sufficiently to build up pressure in that way.
    DMiller likes this.
  8. Truck Shop
    Dec 8, 2015
    6,205
    star gazer
    SE Washington St
    I think a funny one is when a grease fire/flame up occurs and windshield washer fluid is used to put it out.
    DMiller, RZucker and funwithfuel like this.
  9. funwithfuel
    funwithfuel Senior Member
    Mar 7, 2017
    3,649
    Mechanic
    Will county Illinois
    Never saw you show your "dark side" like that before. :)
    RZucker likes this.
  10. DMiller
    Feb 22, 2010
    10,308
    Almost Retired
    WHOOPSIE!! POOF!!
