Care required using gas axe
I was sent these photos. They are from a JLG telehandler steering linkage. The story is that the mechanics assigned to replace the ball joint between the steering cylinder and the track bar couldn't break it loose from the bar. It was put in a vice and heated in an attempt to loosen the threads but with no success. Just as they walked away from it to think about a Plan B to try to break the thread loose the joint exploded as you see in the photo. Fortunately nobody was hurt. There must have been some major force inside that ball joint to peel it open like that.
JPV
S.W. Washington
Wow, have had to do the same thing, never dreamt it could do that! Will file that one away....
repowerguy
United States southern Ohio
mixer truck mechanic
At a former job, a couple guys were trying to get a drag link off a Phoenix mixer with heat and it blew the crimped cap off with a LOUD BOOM! It narrowly missed a guys head and went the width of the garage [75' or so] and hit the wall next to me.
We chalked it up to hyd. pressure from the grease expanding in a confined space.
Scary stuff indeed.
funwithfuel
Will county Illinois
Mechanic
I'm having a hard time understanding what causes the catastrophic effect. Is it uneven heating and cooling to a hardened material? Is it trapped fluid? What could cause that release of energy?
92U 3406
Western Canuckistan
Wrench Bender
I did that exact thing on a G12 JLG a few years back. It split in half and puked grease smoke out all over the shop. For some reason JLG is horny for loctite on those threads. I swear they fill that damn cavity full before threading in the tie rods. A 4 or 5 foot pipe wrench with 2 guys is usually needed to bust them loose when cold. With heat its a one person job. We actually bought a big tap to clean all that old loctite out so we could thread them back in by hand. New loctite of course but not half a litre like was in there originally.
I haven't seen one cut apart, so I'm speculating here. I think there is a nylon/polypropylene/plastic thrust washer inside the socket part of the joint. Is it possible that heating it could release some sort of combustible gas that combined with the grease in the joint could cause an explosion..?
One thing I have no idea about is how hot the guy with the gas axe actually got the piece before it went bang. For all I know it could have been red hot.
92U 3406
Western Canuckistan
Wrench Bender
I think its just from the hot air/hot grease expanding in behind that ball stud. With all the movement during turns the surfaces of the ball and socket probably get super polished and seal up tight so nothing can vent out around it.
When the one I did popped I had it warm, not near red hot, focusing the heat around the flat spot by the threads. After that I started heating the end of the steer cylinder rod instead. Never had another one pop again.
funwithfuel
Mechanic
This all got me to thinking. Something I'm really not a fan of. We had a class on hydraulics when I worked for the Volvo dealer. The instructor explained that we ALL need to be more cognizant of where we apply a torch.
Something I had forgotten about from automotive times. Some bearing side seals as well as high pressure o-rings contain flourene, iirc which when heated produces a carcinogen which becomes caustic and aggressively attacks animal tissue. The result would require the surgical removal of affected flesh. I have personally never witnessed or observed this. Only what I've been taught and passing on to all of you.
Perhaps flourene is not the proper name. I looked up msds sheets and show no long term or chronic effects from decomposition.
funwithfuel
Mechanic
We all need it from time to time. I guess that's why I'll never B!tch about going to an annual refresher. I had completely forgotten about all this, till Nige posted about the rupture hazard. Another that I'd have never guessed in a million years.
Thanks Nige, got the old noodle working a bit.
excavator
Pacific North West
We had something similar happen in our area a number of years ago in a shop that works in the hydro-electric industry. A guy was heating a cast steel prop to remove it from the shaft. The prop had a small casting flaw which had over time filled with water. As he heated it up the water turned to steam and eventually blew out and a chunk of metal hit him in the neck, killing him. Makes you stop and think about how many times we've done things like that.
Ct Farmer
Connecticut
The burning/overheated Viton is nothing to mess around with. When burned it produces hydrofluoric acid which is one of the strongest acids known.
The odd thing is the burns don't have much pain until they are very deep. They are also hard to stop - baking soda won't work, you need a specific base made to neutralize HF and even that is a crap shoot. Burns often require surgery.
Hydrofluoric contamination is a serious problem on vehicles that have been in a fire as the Viton residue is very contaminated with HF and remains active indefinitely.
Only certain gloves are resistant to HF. Choose wisely.
RZucker
Wherever I end up
Mechanic/welder
Yup, there are specific warnings in the Detroit Diesel manual about melted down crosshead pistons with burnt seal rings under the piston crown.
willie59
Knoxville TN
Service Manager
Nige, I do declare, you've posted something I've never seen before, and I'm damn sure curious as to what caused that. Strange indeed in that the only logical reason the wrench bender is replacing the joints is because they are worn. Rubber seal has long gone, grease lube quickly follows in being long gone, joint wear progresses until it's worn slap out. As a matter of fact I'm doing this very repair on a Genie 1056 telehandler for the same reasons. So...with all this slack and worn out stuff, what-in-the-heck caused this failure? I'm perplexed!
92U 3406
Western Canuckistan
Wrench Bender
A lot of times in the extreme cold up here the steering cylinder seals blow out. Unfortunately that means the tie rods need to come off so the cylinder can be resealed.
Vetech63
Oklahoma
I would like to know myself as I have torched numerous ones off with no problems.
