Can't loosen sprocket bolts on T-180
RZucker
Wherever I end up
Mechanic/welder
I pull 1/8" pipe plugs out of roller cone drill bits all the time by heating the plug red hot and letting it cool They usually spin right out. A tight fitting torx bit would be my choice on this one after the heat cycle. In this case only an oxy-acetelyne torch will do with a #3 or 4 welding tip to concentrate the flame.
john146
Central FL
The bolt is rusted and not just stripped. In this case the main challenge is actually figuring out what would grab on to the plug rather than how to get it to move. I can't get anything to weld to it without also getting weld on the case. I tried welding + grinding and I suppose it worked for a few cycles, but I'm at the point where I'm unsure how much of the original bolt remains.
RZucker
Wherever I end up
Mechanic/welder
Ok. Do it your way.
john146
Central FL
If I can drill deep enough to create a hole for the torx, I'll go for it. What's the worst-case scenario if I drill through the bolt?
worst case is you contaminate the oil, give up and stick a cork in it, run it and it fails. Anytime you open something up, you're taking a chance, so don't worry about it.
I'd weld that bugger. Rig up something to hold a washer, or nut over that hole and weld up the center of the hole. All the way from the bottom to the top of the nut. Ideally you'd step down the amps so you don't melt the whole nut off finishing up, but you can stop welding at that point, let it cool a second and finish.
Heating with a torch will do the same thing. Not a small propane torch, you need to get it hot fast so the metal upsets and shrinks when it cools, this is what you're after with welding, not getting something bigger to grab.
IF you drill it, I wouldn't use an easy out, I'd drill it through, use a hacksaw blade or jigsaw blade and cut through the threads, then collapse the shell with a pick or small chisel. Use a drill just smaller than the threads, and saw about halfway through the threads, you'll see them easy enough as you cut, by hand.
Mobiltech
Sask.
If this is a fill drain plug you are trying to get out it doesn’t really matter if you actually get the plug out. Drill it right through and drain or fill unit with oil then weld the outside of the hole shut so it doesn’t leak and your back to where you are now with a sealed unit. Sounds barbaric but in your case you’d probably be better off in the long run. Deal with it properly the next time the drive is apart for repair.
I would have welded it out with a stick welder and a unichrome rod. Or drilled it and tapped it to the next size plug.
john146
Central FL
This idea sounds like the "nuclear option" to me. But I'm listening. How do I minimize contamination with shavings? I guess it's a pretty tight space as it only takes about 2 oz of oil.
Maybe I can weld through the case, drain/fill, and then weld back on top? Would slag get inside the housing?
I've been trying to weld on top of the bolt/in the bolt, but I can't manage to do it in a way where it doesn't also get weld on the housing, sealing it shut yet again. Does it even matter if weld gets on the housing though?
Vetech63
Oklahoma
vetech, yep, that did it. Actually, 5' cheater with a 1/2" drive worked for me. Man, this is the most difficult bolt I've ever had. It smells bad, too. What is the thread/diameter of the three bolts I need to actually push it out?
They are usually the same thread as the sprocket bolt itself, but don't hold me to that! LOL I have seen a lot that are different also. I would also suggest that you use NEW sprocket bolts.
john146
Central FL
I have much bigger problems now, but I think it ended up being either a 1/4 3/8 bolt. Was a pretty tight fit
92U 3406
Western Canuckistan
Wrench Bender
I've had good luck with coating the drill bit in heavy grease. Clean it off and reapply the grease just before the bit breaks thru. The grease will collect a lot of the shavings.
john146
Central FL
I got the bottom plug out using speed out, the top plug still won't move. It's draining (black) oil. I can try and inject the new oil using a syringe. Would that work?
Tags
Connecticut
Rotate the drive so the plugs sit at 3 & 9 and pour the 2 oz in and get a new plug, put her back together and go to work. My a$$ is still chapped by the fact you need to disassemble sooooo much to get to something that SHOULD be EASY to service......
673moto
NorCal
Slacker
Holy hell!
I’m sorry I steered you towards changing that oil.
Mine were pretty rusted but I soaked with pb blaster overnight and then used a propane torch the next day to cook them after I dug out the hex with a small pick.
I’d say you win the determination award for the month!
john146
Central FL
and I still haven't done the other side yet!
In order to try and flush as much of the shavings out, I flushed it with 80w90 gear oil before putting the real thing. I don't think there were any actual shavings in there (other than perhaps fine metallic dust).
And here I thought that removing the tracks and putting them back on would be the hard part. That took only 20 minutes.
673moto
NorCal
Slacker
Oh wow! Good luck with the other side... i’d go with pb blaster soak and then get a small flat blade screwdriver to clean out the hex.
Hit it with a plumbers torch for a few minutes. (I used the yellow map gas).
Tap the Allen in with a hammer so it’s seated and then break those loose!
john146
Central FL
Well, the other side is a wash. I got the top bolt out almost as a hollow shell with a reverse bit... The bottom, I tried drilling through, but I drilled at the wrong angle apparently. At first I was wondering why the drive oil was so nice and clear. Then I saw it was quite a lot of it... then when I turned it on to raise/lower the bucket, the "gear oil" squirted out of the hole. So now I need to remove the million rusted bolts and take apart the drive motor, and maybe just maybe I won't need to pay for a new motor. FML.
I suppose the deal I got on it was good enough that a new drive motor won't be the end of the world... but ugh.
673moto
NorCal
Slacker
Damn... don’t worry about buying lotto tickets cuz with your luck you’d end up owing them money!
Watch some Andrew camarata vids for the hell of it... he seems to be the patron saint of fixing hashed equipment!
Here:
john146
Central FL
Wow, his machine is so clean... all of those nuts in the back are horribly rusted and caked with god knows what. I've managed to get them loose but I might just take an angle grinder and cut off those bolts. They're nasty.
Also, that video is basically him spending an hour removing the motor but not actually rebuilding it. :|
673moto
NorCal
Slacker
Yeah... for the average guy i’d say rebuilding a final drive is a bit much.
Best to send those things out.
I’ve heard Texas final drive is reasonable.
