Shovelworks
I'm changing the coolant in my 2000 312 excavator. Can I use extended life coolant I get at Sanel?
Check the label. Does it meet Cat EC-1 specification..? If yes you can use it with confidence, if not walk away, or better still run, as far and as fast as you can in the opposite direction.I'm changing the coolant in my 2000 312 excavator. Can I use extended life coolant I get at Sanel?
TBH I can't understand people who nickel & dime over saving a few dollars rather than buy good quality fluids when the machine they will be used in is worth tens of thousands of dollars. Maybe it's me that's out of step but I doubt it.
Peak Final Charge is the most common extended life coolant. Whatever you do, flush with distilled water, and mix with distilled water if it's not premixed antifreeze. Flush with rainwater if you're cheap.
