Can damaged JIC fitting threads be fixed/rethreaded?
nilzlofgren
New Jersey
I put a new hydraulic pump in my 580K. Everything went well, until I was reinstalling the lines to the oil cooler, and one of the lines started to cross thread. Is it possible to repair the damaged threads on the fitting with a rethreading die? Or can the old fitting be removed, and a new one be rebrazed on? Thanks. John.
Mark250
victoria,Australia
heavy equipment technician
depending on how bad it is I would say yes .the JIC fittings are based on the unified national fine thread base (UNF) and is a common thread type for bolts and nuts
Mark
Jonas302
mn
Might be able to chase them with a thread file or triangle needle file can probably be saved with some patience
kshansen
Central New York, USA
While we're talking about JIC fittings. Does any one know that Cat and maybe some one else makes "gaskets" to salvage damaged fittings?
They a thin copper cone shaped things that slip over the tapered end of the fitting and will compress and seal them if there is some small nicks in the sealing area of the fittings. Yes most fittings are best to be replaced with new but in a pinch when an odd or difficult to replace fitting is seeping they can be a life saver. If there is any interest I could do some digging and see if I still have the information with the sizes and part numbers.
