Pep Joe
What is engine performance without FLS and FTS codes programmed and without injectors trim codes programmed?
Am asking cos today i connected a Cat ET to a C9 (sn:thx00719) and found they were not programmed. Engine working fine but has active codes for the none programmed parameters. the engine is used on D6R sn WRG00195.
Need advice on if i should leave the Doxer like that or get the codes and do the programming.
Thanks
Thanks
