C13 Cat/Peterbilt...low current on all 6 injectors
Discussion in 'Trucks' started by DslDrew27, May 23, 2020 at 8:32 PM.
  1. DslDrew27
    DslDrew27 Member
    Jul 25, 2017
    13
    PA
    C13 KCB prefix
    out of the 10 or so times i cleared codes and started fresh, i got the primary loss of speed signal twice, and all 6 injectors come up low current, every single time. codes only come on at high rpm, say 1800 to 1900
    new set of fuel filters, new crank sensor, cam sensor coming on tuesday.
    Ran out of bucket straight from transfer pump, so not sucking air. still getting same codes.
    haven't pulled valve cover yet to check wiring, but from what i understand there isn't a single common wire.
    gotta be a broken or loose wire or connector, or ECM issue.
    Any help is appreciated.
    thanks.
    Drew
  2. Nige
    Nige Senior Member
    14,507
    Try the attached porocedure and see where it takes you.......
    • Doc.pdf
      File size:
      234.4 KB
      6
    DB2 likes this.
  3. RollOver Pete
    RollOver Pete Senior Member
    Mar 6, 2007
    1,254
    Operating Engineer/mechanic
    Indio, Ca
    Check all and I mean all of your grounds.
  4. Mark250
    Mark250 Senior Member
    Aug 30, 2015
    1,043
    heavy equipment technician
    victoria,Australia
    Disconnect P1 connector from ECM and check that you have good power supply to pin # 48,52 and 53
    Also check that you have good ground at pin # 63,65 and 67
    you must check with P1 disconnected to ECM because they are connected by an internal buss bar
  5. DslDrew27
    DslDrew27 Member
    Jul 25, 2017
    13
    PA
    Thanks for the replies. I’ll let you know what I find out on Tuesday, hopefully I won’t get interrupted too much. Road calls seem to be picking up in frequency.... had one on Friday, air compressor discharge discharge line, thankfully it was 20 minutes from the shop. The 100 mile one way road calls suck!
