: just out of interst did you use mild steel for the link arms, i know Kubota use some kind of cast steel? Also what did you use for your pins, are they hardened or just mild, also have you got hardening equip?
All the parts are either T1 plate or 4140 heat treated. I will be showing the custom pins that I have made for this project soon. The main bucket pivot pin is made from S7 and heated treated to 55 -57 rockwell C all the other pins are 4140 heat treated to 50-52 rockwell C
Our bobcat mini the Aux hydraulic line crosses on the top part of the boom so it does not obstruct your view. .
Looks good but the only thing I would suggest is to route a solid hydraulic feed pipe to the bottom of the thumb cylinder, if you get something stuck in the thumb and lift it up, it may damage the hose.
Looks good, hate to think how much the total cost is, including labour.
Guess quality costs?
Do the sides of the thumb unbolt, so you can just have the center section?
