building a new heavy equipment shop?
check
in the mail
Heat and insulation can nearly double the cost of a shop if you go with any significant R value. Up North open wings on the eave sides can be a good compromise. Only half the structure would be enclosed and insulated, the rest only covered. There you can park long term low priority projects and work on them as weather permits. The wings can be dirt floor to keep taxes down. Disadvantage of this is that, being on the eave sides, they have lower ceilings. If you try to do this on the gable ends, you always have a machine to move before you can get another in the door.
Cheap "old" Geezer
The quarry at St. Charles had some massive shops, all air sent thru lines in the floors, mostly to Tower Jib cranes where the bases were used as extra air supply tanks. Had drains on those we hit at least once a week, do not remember them ever water loading too bad. Believe that foreman told me had embedded 2" sch 40 steel pipe (Welded) in the floors to the towers, came up alongside the bases and connected with flex line. Shops always too small, would end up working on half the workload Outside under eave awnings.
JD955SC
The South
Small Indoor pressure washer bay for cleaning components to knock the mud off before tearing stuff apart.
Good organizational/storage racks for chains, big prybars, rigging, cribbing, chocks, jumper cables, specialty tools, etc.
A good set aside area for jackstands, jacks and oil drain pans and other things that have to stay on the floor but you don’t want in the way
I’ve been wondering if it would be possible to pour concrete ramps to get a machine up off the ground for easier belly pan removal and work under the machine. At work we make do with running D3-D6Ks up on 6x6 blocks for some room working under them but it still isn’t fun.
Position benches under reach of cranes
Definitely good lighting. I’d love to have natural light without opening doors
Former Wrench
Montesano, WA
Retired
This is a repeat, but steel rails and anchor posts embedded in the floor. Having a place to keep racks and shelves for parts and special tools. Extra fire extinguishers. A few hooks to hang coveralls, rain gear, winter coats. Plenty of electric outlets. Think ahead about a steam cleaner, where you would put it, and how to plumb in a sump. Having a press is nice too; buy new/used or homemade. Running water if possible to hose the floor once in awhile to remove mud and dirt. There's more but I don't want to put you in the poor-house before you get going.
RZucker
Wherever I end up
Mechanic/welder
A good alarm system with battery back up. Mine is setup to call me, the sheriff's department, and the alarm company. Both door and motion sensors. It also sends me an e-mail if it hasn't been set by 6 pm.
Cheap "old" Geezer
OMG, now it comes, Wait for it, Wait!>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Popcorn Machine!!!!!!! Cannot forget Popcorn machine!!
Cheap "old" Geezer
Can see cribbing timbers or crane matt timbers for crawlers to run up on, not sure would like to try to set concrete ramps and run them up on them.
crane operator
sw missouri
.is this a 250K shop?
Depends how big. If you want just a single bay shop to work on one piece at a time, you might build the building for that, if you already have the ground. The shell of the building isn't expensive. Its the concrete, water, sewer, electric, insulation, windows, doors, compressor, overhead crane, etc. etc. etc.
If you don't own the ground, and have to buy commercial zoned land, bring in water sewer elec, pour concrete, and want a 3 bay 70 x 100, I think you would be staring at $1 million.
Now, if I was just wanting to get out of the sun and the wind. I think I would pour a 60' x 80' slab, and set 4 -40' high cube conexes around the outside perimeter. Then cover the center with a fabric arch building. But it doesn't get that cold by me.
