Building a custom excavator
Discussion in 'Compact Excavators' started by Coastal, Sep 24, 2017.
  1. hvy 1ton
    hvy 1ton Senior Member
    Jul 24, 2006
    1,745
    Lawrence, KS
    My first guess was crazy a Schaeff excavator. The more I looked at it the more convinced I was that it was a Deere harvester cab on an 080.
  2. Mark13
    Mark13 Senior Member
    Feb 28, 2013
    251
    IL
    That's a pretty wild looking machine!
    For the plate packer, did you weld a centering "ring" right to the plate packer or did you weld the ring to a plate then bolt that plate to the plate packer so you could use it for compaction and also driving posts?
  3. Coastal
    Coastal Senior Member
    Feb 15, 2006
    321
    BC, Canada
    With the content of the original thread, that's probably a pretty good guess. lol!
    Yes it needs a ring...and I've modified it into an Oval with partitions, so you can use different parts of the plate to pound in different conditions. The outer edges of the plate actually drive better than the center. I welded it on because I have no patience to drill holes in 1.5" plate. ;)
    Mark13 likes this.
  4. Ronsii
    Ronsii Senior Member
    Jun 26, 2011
    3,544
    s/e Heavy equipment operator
    Western Washington
    Sounds like it will be an interesting project :) how long are you going for? any longer than the original extended condition? or something really long...
  5. Coastal
    Feb 15, 2006
    321
    BC, Canada
    The same length as the original fully extrended, with the long straight boom, any shorter and the geometry doesn't work for tree shears and grapples working in close. :D
  6. John C.
    John C. Senior Member
    Jun 12, 2007
    9,254
    Is this going to be a thinning machine? Are you making another swiss army knife with a quick coupler and an extra circuit for rotation and other things?
  7. Coastal
    Feb 15, 2006
    321
    BC, Canada
    Yes exactly the plan, I'm mating a John Deere 75c stick to the factory stick, I don't plan on digging with it. Just felling, raking, grapple work etc.
    Labparamour likes this.
  8. Dom
    Dom Active Member
    Oct 29, 2008
    33
    Moncton, NB, Canada
    I worked for Rocan Forestry and we likely imported that Neuson. We were the North American rep for Neuson forestry products, which later got named MHT. I imagine it has a deutz 5 Cyl? They were great thinning machines. The parallel loader worked great. Just be careful with the log swing base, there were a few that cracked. I believe the loader was from loglift, but my memory is fading. There was one for sale in Nova Scotia not long ago.
  9. Coastal
    Feb 15, 2006
    321
    BC, Canada
    No way! This is a deutz 4cyl, 100hp. They have eliminated the swinging boom I heard it was a weak spot as well. I bought this one in Nova Scotia actually and had it shipped west.
  10. Dom
    Dom Active Member
    Oct 29, 2008
    33
    Moncton, NB, Canada
    Right, it was a 4 cyl. See, my memory is fading hahaha. We had a similar loader on the Rocan Enviro, which was a wheeled harvester for thinning. They both ran the Logmax 3000 sized harvesting head. Enjoy the Neuson, its a nice machine! I saw one on the roadside last summer, but I can't recall exactly where it was.
    When it came to the MHT 20 Ton harvesters, they were the most productive harvesters in the area. We didn't have good support from MHT though. We couldn't get parts to rebuild pumps for example.
    Nonetheless, enjoy the Neuson! Its a nice machine.
    Coastal likes this.
  11. Coastal
    Feb 15, 2006
    321
    BC, Canada
    [​IMG]
    [​IMG]
    [​IMG]
    Made some headway, moved the cylinder for the stick to the bottom, what an amazing increase in lifting power. In the factory position I couldn't budge those 2 logs with the stick controls. It's set at 4400psi...and it wouldn't even try to lift them. Now it lifts them effortlessly. I was hoping for a bit more extension, but that's all I get using the factory cylinder and trying to let it close up nice and tight. Now the Deere 75 stick is attached, I can put the cylinder and linkage on, and get some hoses to the cylinder and we're getting close to work ready.
    As it sits, it has 9.5m reach at ground level measured the way equipment brochures measure from the center of the swing bearing. A new 135 sized machine is around 8.2m for comparison sake.
    GregsHD, hvy 1ton, Batkom and 4 others like this.
  12. Coastal
    Feb 15, 2006
    321
    BC, Canada
    Getting close now, just need a quick change and some plumbing.
    [​IMG]
    Pixie, Batkom, GregsHD and 4 others like this.
  13. John C.
    Jun 12, 2007
    9,254
    I like the crown of snow on top of the cab protector. The new stick looks great.
    Coastal and Labparamour like this.
  14. centerline
    centerline Member
    Jul 11, 2016
    16
    Salem Oregon
    there are lots of good ideas built into that little machine... just dont overlook the stress load thats being placed on the superstructure lift/tilt cylinders when they are extended... it may be more than you realize as the machine is lifting, swinging and being shock loaded at times... its an extreme dynamic load, rather than a static load which is not nearly as stressful....
    Coastal and old-iron-habit like this.
  15. Coastal
    Feb 15, 2006
    321
    BC, Canada
    [​IMG]
    Getting close now.... Building a quick change tomorrow, spent today converting the hydraulic system from harvester to excavator, moving pilot circuits, adding a directional valve, and finally making it work on the joystick buttons.
    colson04, Ronsii and donkey doctor like this.
  16. colson04
    colson04 Senior Member
    Apr 11, 2016
    1,056
    Delton, Michigan
    Do you still have the DT360 swapped super duty? I was looking into doing the same and found your build thread on another site
    Your custom builds are truly impressive, I've really enjoyed following your unique projects.
    Coastal likes this.
  17. Coastal
    Feb 15, 2006
    321
    BC, Canada
    No I sold that a couple years ago... I have a boring Dodge now. That truck was one of my favorites.
    colson04 likes this.
  18. Coastal
    Feb 15, 2006
    321
    BC, Canada
    Got it up and running doing some testing... Pretty good so far other than a couple big leaks I missed.
    [​IMG]
    [​IMG]
    Camshawn, JPV, colson04 and 3 others like this.
  19. rsherril
    rsherril Senior Member
    May 2, 2009
    261
    Geologist, Retired from teaching sciences
    Far West Colorado
    These pictures are calendar worthy. Wow.
  20. Coastal
    Feb 15, 2006
    321
    BC, Canada
    Thanks! Good ole Samsung!
