Bucket job for the 120
Discussion in 'Welding' started by skyking1, Feb 3, 2021.
  1. skyking1
    skyking1 Senior Member
    1,497
    I got a quote the other day for a professional shop to overhaul the bucket, $2280.
    This seemed a bit much, and I set about straightening it. I got started but the crack was snagging and I had to go do some work.
    Fast forward and I need to do a big job with the 120. I did not want to take a cracked bucket, so I cut the crack so it would pass freely and heated and docked it out straight-ish.
    [​IMG]
    [​IMG]
    Sorry, no weld pictures. I will get those later. The bucket gets a 3/8" by 2" armor wear plate right under that crack.
  2. Bls repair
    Bls repair Senior Member
    Jan 21, 2017
    1,615
    Equipment operator,mechanic
    S E Pa
    When I see a crack in that area of a the bucket usually the outside edge worn out.
  3. Bls repair
    Jan 21, 2017
    1,615
    S E Pa
    $2280 total rebuild or repair?
  4. skyking1
    1,497
    It is worn out in the bottom there. The armor strip was worn off, that used to stick out 1/4" past the side. When I get it back in the shop I will touch up that weld, and then bend some AR400 around the bucket bottom.
    That was 2280 for a repair.
  5. Bls repair
    Jan 21, 2017
    1,615
    S E Pa
    Gold isn’t good for bucket repair,to soft:D
  6. skyking1
    1,497
    Agreed! That was straightening the bottom, scarfing off and replacing 3 crossways wear plates and the two on the edges. I have already flipped the cutting edge around.
