Bucket Help Please
Discussion in 'Compact Equipment Attachments' started by Reuben Frazier, Apr 4, 2020.
  1. Reuben Frazier
    Reuben Frazier Member
    Mar 25, 2019
    20
    NE Texas
    I’m needing some advice if anyone has a little to spare. I have a CAT 299 D3 and I’m trying to decide which bucket to install teeth on. I have a standard CAT bucket and a new 80” CAT MP bucket with cutting edge to choose from and I’m torn as to which bucket to install a set of teeth on. I rarely use a bucket but since I had 2 of them I figured I might as well have some teeth on one. Any thoughts?
    DMiller likes this.
  2. Delmer
    Delmer Senior Member
    Jan 4, 2013
    6,001
    I figure the teeth go on the narrower and heavier duty bucket. You're going to be using the teeth for digging in tougher conditions, so you want the stouter bucket. Use the wider one for fine grading, spreading, etc.
    Or does multi purpose mean it's a 4 in 1 bucket? In that case what's the width of the other bucket?
    DMiller likes this.
  3. Reuben Frazier
    Mar 25, 2019
    20
    NE Texas
    The MP is a 4 in 1 and both of them are 80” CAT buckets.
    DMiller likes this.
  4. Delmer
    Jan 4, 2013
    6,001
    That makes it tricky. probably doesn't matter too much though. Do you like to use the MP bucket to grade with the bucket open a bit to control the depth? that would be the only reason I wouldn't want the teeth on the MP bucket, if that was more useful to you for grading and final cleanup type stuff than having the MP bucket for grubbing, piling and heavy digging where you'd want the teeth.
    DMiller likes this.
  5. Tags
    Tags Senior Member
    Feb 19, 2012
    943
    Connecticut
    I have a tooth bar on an 84" 4n1 Construction Attachments bucket and have never removed it. If you need to clean up material off a hard surface like concrete or asphalt, I open the bucket and use either the smooth edge on the jaw or the smooth edge on the "dozer" side.
    DMiller likes this.
  6. Welder Dave
    Welder Dave Senior Member
    Oct 12, 2014
    3,787
    I think the standard bucket will dig better than the 4 in 1 and if you're digging heavy clay will lift more because the bucket is lighter. How do the teeth attach? If they bolt on could use them on either bucket.
    DMiller likes this.
  7. Reuben Frazier
    Mar 25, 2019
    20
    NE Texas
    Thanks for the input guys, the teeth are bolt on’s and I could easily move them if I wanted to so I think I’m going to try to put them on the 4n1 bucket.
    DMiller likes this.
  8. KSSS
    KSSS Senior Member
    Feb 27, 2005
    2,994
    excavation
    Idaho
    I have an 84" Bradco that I put a tooth bar on. I typically buy extended lip buckets and typically Virnig. However for a tooth bucket I think there are some things to consider. The times that you need a tooth bucket are for obviously hard digging. The teeth extend the lip of the bucket out further, this increase in tip radius reduces the machines bucket breakout. The Bradco that I put the tooth bar on is a shorter lipped bucket, but by the time you factor the length of the teeth you are essential at an extended lip configuration ( so if you put teeth on an extended lip bucket you are further reducing breakout when you need it the most). Your Cat I think has around 7K in breakout, which is factored typically with a shorter lipped bucket (provides a more impressive breakout number, which is common). To maximize what breakout you have, I would consider the length of the bottom of the bucket with teeth on it. If your working your machine in tough breakout conditions, it can matter.
    DMiller likes this.
  9. Reuben Frazier
    Mar 25, 2019
    20
    NE Texas
    Well brother you took that to another level lol, great info and I appreciate your time and opinion. To be honest I rarely use a bucket but I will look at them tomorrow to see what your referring to and report back. “Weather Permitting” it’s a swamp here
    DMiller likes this.
  10. RTSmith
    RTSmith Senior Member
    Oct 23, 2008
    359
    Amateur demolition & dirt pusher
    Middle Tenn.
    I figure the regular bucket can hold more than the MP. When I am seriously digging like with teeth, I'd like to stay in the cut and fill it up. So bigger capacity gets my vote And yes, They unbolt, but it seems to be rare we want to take the time to do so....
  11. RTSmith
    Oct 23, 2008
    359
    Middle Tenn.
    I do find it interesting Cat suggested a 80". I have a 289D with wide tracks and they suggested a 78". When I got a 299D3 with wide tracks they suggested a 83". Looking at them side by side the 83" has noticeably higher back for more volume. Data tag on it shows .89 yard as I recall.
  12. Canuck Digger
    Canuck Digger Well-Known Member
    Dec 24, 2012
    207
    Business Owner, Equipment Operator, Fishing Guide
    Mission, BC, Canada
    Since the 4 in1 is kinda like a do it all bucket, perhaps I'd put the teeth on that one. Leave the other one for grading/bulk material handling only. I think a lot of it depends on the type of work you do most.
  13. Tags
    Tags Senior Member
    Feb 19, 2012
    943
    Connecticut
    On the CTLs I like having the bucket wider than the machine by a couple of inches, I feel it stops a lot of material from falling on to the tracks when digging.
