Brake lights
bluetag
MN
Working on a sterling 2008
No brake lights on R side only got 5 volts to rear of truck?
Mike L
Texas
Self employed field mechanic
look for chaffed or bare wires somewhere between the back of the cab and the taillights. Does it have a junction box at the back of the frame? If so look in there for corrosion and bad connections. Sounds like you’ve got some green wires somewhere
Cheap "old" Geezer
Last weeks spilled coffee/coke/water jug fluid in the rear cab floor area maybe??
bluetag
MN
That was all back probed. We seem to have it when you put a heavy load on it. We just put in a new controller in and looks like this was the problem. Thanks for your help.
