Boxer 427-Hydraulic fluid coming out of vent hose (ALOT)
Discussion in 'Mini Skid Steers' started by VOL427, May 21, 2021.
  1. VOL427
    VOL427 Member
    Jun 30, 2012
    12
    Harrison, TN
    I have a 2006 Powerhouse ProTrax Boxer 427 Mini Skid Steer, and it is pouring hydraulic fluid out of the vent hose after being in use a short time. I have just replaced the main hydraulic hoses connecting pump and filter, and replace the filter. Through my research on the web, the major cause suggested was overfilled. It is not but removed fluid to below dip stick, still leaks alot. Any suggestions would be appreciated
  2. lantraxco
    lantraxco Senior Member
    Jan 1, 2009
    7,698
    Elsewhen
    Is the oil frothy? Sounds like she's sucking air someplace and blowing back into the tank.
  3. VOL427
    VOL427 Member
    Jun 30, 2012
    12
    Harrison, TN
    I believe you are correct. Tried with fluid low and still leaked thru vent tube......then like a dummy I unscrewed the fluid dip stick (engine off but fluid hot) and it came out like a brown frothy volcano. Tomorrow I am going to refill the tank to proper level and try again. Can anyone tell me if it should be checked with the dip stick screwed back in then removed, or stick removed and rested on top of hole to check level. Result will be affected by 1/2 inch.
  4. Zewnten
    Zewnten Well-Known Member
    Apr 2, 2018
    115
    Earth
    Try spraying a bit of foaming shaving cream around each suction hose. That'll show were its sucking quickly. Dipstick screwed down or not probably doesn't matter as the hydraulic tanks are pretty large.
