Bought a Bucyrus Erie 30B lattice boom 60 ton crane
ichudov
United States
I know that it is kind of crazy but I bought this at auction today for $11k plus BP.
Pictures are here:
https://www.machinerymoverschicago.com/blog/Bucyrus-Erie-30B-Crane.jpg/
It supposedly has a rebuilt Cat 3306 engine. It was owned by Archer-Daniel-Midland company which makes corn syrup and corn alcohol.
My question is, is the 80ft boom too short or not? Anyone in Chicago wants to make some $$$ helping me remove the boom for transport? (I will hire a OSOW lowboy, cannot haul it on my five axlesBucyrus-Erie-30B-Crane-0.jpg )
crane operator
sw missouri
Well- its too long for unloading trucks and close heavy work, and its not long enough for setting steel. So to answer- its both to long and too short. I don't think you'd have any trouble finding some more boom for it if you wanted, and you can just knock out a section for unloading trucks. Looks to be in good shape.
It comes apart readily if you want to haul it yourself. It was one of the first that was really built for it from the get-go.
Congrats that is a nice find.
ichudov
United States
DO you know any videos on how to take it apart? I literally have no clue but would like to learn.
Does it need a beam trailer?
ichudov
United States
So, in principle, you can add an extra section? All I need is to find something for sale right?
ichudov
United States
Skiking1, I will check with the sale person. I have never operated a lattice boom crane (I have a hydraulic RT crane only).
Wait, Is that a dragline crane or not???
crane operator
sw missouri
It should have expandable tracks, so with the boom out and counterweight off, you should be able to retract the tracks and walk it on a lowboy. A beam trailer would also work if height is a issue on hauling. I'd send the spec sheet to the hauling company, and let them decide what they want to send for a trailer. You don't know what they have available for trailers, they do.
willie59
Knoxville TN
Service Manager
Conventional cranes and booms were designed to be converted and fitted with components used for conventional cranes, jibs, clams, drags, orange peels, the list goes on, just requires components necessary to do it. Most rigs that use a fairlead have a "third drum", I don't know if that's necessary, been away from crane rigs too many years to remember, just saying the rig is the base plant, all other attachments just require the proper components for the base plant to work them.
John C.
You only need two drums to work a drag line and most I've been around had angle iron booms. My dad's crane was a Koehring but was operated with both a clamshell and a drag line. You will have to have a fairlead to run the drag. It looks like the machine may have extra counterweight. I've seen a couple of machines that were set up for special applications like that. Those usually have to be removed for transport. Steel mills and aluminum smelters had drop weights on them for busting up slag. Usually cranes that size are set up with track frames that can be moved in for transport but you will need to check to see if that is the case here. The boom middle sections are usually dropped out and the butt and tip sections connected to transport the machine. If the machine has been in a plant doing only a couple of tasks, you might have to spend some time with a grease gun, a case of penetrating oil and then run things to get them working again before you try walking it on a trailer. I seem to remember Bucyrus used air controls so maybe time will need to be spent fixing air leaks.
Nice find and good luck!
Tugger2
British Columbia
Hows the moving going ? I just brought a 30B series 4 home to my yard a couple of months ago.Took me a day to sort out narrowing the tracks and breaking it down. Id be there in a heartbeat to help out if it werent for the current state of the world. Pm me if you still need some help.
dirty4fun
N. IL
I ran a 30B just a little while it was set up as a hoe, then changed to a lattice boom. The travel brakes would get oil on them and turning was an issue. Had to put a block of wood in front of the track to get it to turn, but got it on and off the trailer to move it, that way.
Good Luck!
Tugger2
British Columbia
Best thing about those brakes is that you can steer on a hill. The Lima runs a similar system that works well,except for last tuesday while unloading on this bridge job. I walked off the lowbed on a busy mainline ,did a 90 deg. turn to head up the spur. Trouble was one brake decided today was a good day to lock up stopping me crossways on the mainline. Within seconds it seemed like log trucks showed up,loaded and empties.Took me about 10 mins to sort it out and off we all went .
Tugger2
British Columbia
Yes thats true ,but its a crawler . You just walk to where you need to be,none of that fussy outrigger business. Thats as long as your working with good road builders .
ichudov
United States
Does anyone know of a good website or instruction manual on how to operate a friction crane? I looked around and did not find anything.
