SoloTech
My problem is that I've found the remainder of an o'ring inside the governor assembly and have no idea where it came from.
The pump is a BOSCH PE6P120A320RS7138-10.
Originally, the pump was spewing oil out of a small hole, just behind the engine stop linkage. I patched the hole, then removed the 22mm oil filler bung to see what had caused the oil spill, discovering the partial o'ring.
I still have no idea what caused the hole to be punched through.
Would any have any info?
Thanks.
Thanks.
