Boom!
Discussion in 'General Industry Questions' started by Welder Dave, Sep 24, 2022.
  1. Welder Dave
    Welder Dave Senior Member
    7,874
    I had dual batteries in my 5th wheel trailer and 1 of them decided it didn't like being there. Both batteries were new at the same time about 5 or 6 years ago. I wasn't staying in the trailer and finally got around to getting the battery door open. The lock was corroded from battery acid. It blowed up real good!
    HarleyHappy and Spud_Monkey like this.
  2. Spud_Monkey
    Spud_Monkey Senior Member
    Sep 15, 2018
    4,346
    Decommissioned
    At your six
    It froze due to being low in voltage and expanded till what you see, fully charged lead acid battery can survive down to about -80 to -90° F
  3. Coaldust
    Coaldust Senior Member
    May 9, 2011
    2,208
    North of the 60
    Shame on the mess. !
    aighead likes this.
  4. Bumpsteer
    Bumpsteer Senior Member
    Sep 2, 2009
    1,205
    Mechanical designer
    Front seat on the Struggle Bus
    Stored a golf cart for a friend in poor health, he rememberedto keep it charged. Forgot to keep the batterys full of water.
    Over the winter all 6, 6v batterys went dead and froze. No blow ups but all were junk, less than 2 years old.
    Ended up being his sons problem.....
    Ed
  5. Welder Dave
    7,874
    Maybe it was low on water but the batteries were hooked up to a solar panel to keep them charged. Interestingly the 1st charge controller on the solar blew up too. I wondered if it got hit by lighting. Big black mark on the back of the solar panel. It was replaced on warranty and was working great but now I'm wondering if it might be what caused the battery to self destruct.
    aighead and DB2 like this.
  6. Spud_Monkey
    Sep 15, 2018
    4,346
    Decommissioned
    At your six
    Sulphated, I'm sure if you had a way you could knocked it off and saved at least 80% capacity.
  7. Spud_Monkey
    Sep 15, 2018
    4,346
    Decommissioned
    At your six
    That's not self destruction, that's I was too low of voltage and froze then expanded breaking the case off. What do you mean 1st charge controller, if you had two or more in line they better talk to each other or there will be a fight between the two of what to do. Not many CC's talk to each other.
    Batteries only explode when a spark ignites the hydrogen sulfide gases in which you won't have a camper left and more damage based on the fact there wasn't enough air circulation for the battery to off-gas.
    DB2 and HarleyHappy like this.
  8. Bumpsteer
    Sep 2, 2009
    1,205
    Mechanical designer
    Nope, all of them ballooned out like an over-pressureized blimp. Tried every trick I had.
    Ed
    Spud_Monkey likes this.
  9. Spud_Monkey
    Sep 15, 2018
    4,346
    Decommissioned
    At your six
    Yeah that's frozen and plates shorted out against each other to not take a charge.
    HarleyHappy and Bumpsteer like this.
  10. Welder Dave
    7,874
    1st charge controller was disconnected. The battery didn't explode in the winter. May have been a problem with the construction of that battery as the other one that was identical showed no signs of damage. Internal short or something??? I've seen the tops of batteries blown off but this was a bigger explosion. The bottom of the battery compartment is completely open so lack of air flow shouldn't have been a factor. Also have read some people aren't fans of Interstate batteries. I might look at AGM batteries to replace them. They won't spray battery acid everywhere and are a lot less likely to explode.
    HarleyHappy likes this.
  11. Truck Shop
    Truck Shop Senior Member
    11,090
    star gazer
    SE Washington St
    The weight of a battery tells the life of a battery in most cases, in any group. Cheaper the battery the
    less it weighs. 4 things kill a battery, setting over long periods with parasitic draw, shock, extended
    crank times, bad charging system. A battery that lasts 4 years is a good one because of parasitic
    draw of new vehicles. If we get two years out of a set of four group 31HD's that's good, with all
    the crap kept alive while parked. Common issue is internal short {loose plate}, swell up and boil.
    Refer units are tough on batteries, constant vibration, a Delco battery doesn't last long in a refer.
    As far as Interstate brand, my 84 Dodge 150 had two batteries in 23 years I owned it both Interstate.
  12. Welder Dave
    7,874
    It was mostly Interstate RV batteries that got some bad reviews claiming they weren't true deep cycle batteries. Something had to go wrong for the 1 battery to have catastrophic failure and the other one show no issues.
  13. Spud_Monkey
    Sep 15, 2018
    4,346
    Decommissioned
    At your six
    What is true deep cycle, there is no definitive line, all batteries put out so many Ah and there is nowhere a line saying a battery should have this many Ah to be deep cycle. All batteries in lead acid or AGM don’t like below 50%, so to say it’s deep cycle it means if you put it on this application it will run it longer than if you put a smaller battery on it due to Ah’s not a sticker saying Deep Cycle. A group 31 battery is deep cycle to a flashlight as it’s just a starting battery for a 6 cylinder diesel engine. More Ah’s the more lead plates there is and or the thicker they are to store and put out energy.
    Truck Shop and DB2 like this.
  14. Welder Dave
    7,874
    What I've read is starting batteries deliver lots of amps in a short period of time and deep cycle deliver lesser amps but over a longer period and are designed to be drained and recharged often. Interstate apparently aren't true deep cycle but in-between a starting battery and a deep cycle battery. I don't need new batteries right away but when I do I'll try to get some info on good RV batteries that won't break the bank.
  15. Delmer
    Delmer Senior Member
    Jan 3, 2013
    7,882
    Deep cycle batteries will have thicker solid lead plates, thicker seperators, and more room at the bottom of the cell to fill with trash before shorting it out. Most "deep cycle" RV, golf cart?, marine cranking batteries will be chunked pressed lead, and mid way between single cell deep cycle and starting batteries. Automotive starting batteries will be powdered lead with thin plates for maximum surface area, number of cells =volts, surface area of lead =amps.
    Any overcharged lead acid battery produces hydrogen and oxygen, in the exact ratio required for complete combustion, amazing more of them don't blow up.
    Welder Dave and Truck Shop like this.
  16. Truck Shop
    11,090
    star gazer
    SE Washington St
    I throw a soaking wet towel over boiling batteries before removing the ground.
