benmech
Any Bomag single drum Guru's here?
I got called in for a 2016 BOMAG BW216DH, EMR4 DEUTZ, with the problem crank no start. Operator says , there were
codes 5100 and 5140 flasing on the dash. Previous mechanic came and plugged a scan, not sure what he did, it started again, no codes ran for an other hole day, turned of , next day cranking but no start.
I came , plugged a jaltest , just one active code ,, " SHUTOFF TIMER RELAY NOT IN CONTACT".
Just to be sure i checked the crankshaft/camashaft sensors and they are okay.
Normally a serdia software should be used on the bomag i think , but i have no acces to one .
Somebody knows where this relay is located?
