Bolt on extensions
Illinois
We just bought a 10” and 2.5’ bolt-on extension for our AP1055F paver with a SE60V screed. It didn’t come with instructions. Is this pretty straight forward install. I’m only familiar with the D and E model paver bolt on extensions. This looks like a totally different design.
thanks
A bit hard to look for info when you don't even give a Serial Number, either for the paver or the screed.
There are a sh1t-load of Special Instructions for installing/adding/modifying screeds. I think what I might do is download them all and send them to you. You can then make of them what you will.
Illinois
I’m sorry Nige. Paver serial number is TJ501156. Tomorrow morning when I get to work I’ll get serial number of the screed and the part numbers of the bolt on extensions we received.
Here's the R&I for the Screed Extendsions. If you need any more info regarding the detail of Steps a thru f that have to be done before starting then let me know.
  • 486-4620.pdf
  • 486-4622.pdf
  • Sceed Extension R&I.pdf
