RTTR
- Joined
- Nov 29, 2016
- Messages
- 8
- Location
- DeSoto Mo
- Occupation
- Shop Owner, of mechanic shop for Ag and Ind. Eq.
We have a T770 Bobcat in the shop that has an intermitted code W3239 which is Lift actuator not in neutral. Some one before us already install a new actuator. So we ran the calibration procedure on both actuators. Drove the unit around on and off for several days. Would only set the code a couple times. We then switched the tilt and lift actuators, did a calibration again. Drove around again for a few days. Finally today it set the same code again. We have checked the spools for sticking or binding, swapped actuators, performed the calibration procedure with our laptop. Tested voltage, we have the 5 volts on power wire, we have a good ground wire, we have 2.06 volts on the signal wire. So my question to everyone is, what should we have on the signal wire. I would have thought 5 volts. I am thinking we have a bad ACS controller. Any thoughts or help would be great. Thank you in advance.
