I have a T550 that I bought at 700hrs. I noticed water in the fuel after draining a little off the fuel filter as part of a routine checkup at 750 hours. Started looking for a leak and found the fuel return line grommet was sitting out of it's hole into the fuel tank, allowing water to enter. I pressed the line and grommet back in but soon after running and checking it, the grommet was back out. I went to bobcat dealer and bought a new grommet for that application and installed it. Few weeks of use and it was back to the same issue: The new one was popping out now. It pops out while the machine is running. I can put it back in, start and run the machine and then check it and it will be out. But it doesn't happen every time. There have also been a good few times that I've parked the machine and it's been in and when I come back days later it will be out.
Is there a vent that is clogged causing too much pressure? Could it be the fuel cap? The fuel cap doesn't seem to be vented, but it's clean without any gunk or buildup.
Or is there a better way to get the grommet to stay in?
Any help or suggestions would be appreciated!!
