Mike_IUOE
Hi, I've been a lurker here for a while and just made an account .
I am needing some guidance with my 03 Bobcat T300. My power quicktach stopped working and I read willie59's thread about how to diagnose it. He said the cause is usually from a failing pump or drive motor and to check the filters. Well I did, and I have metal shavings in it. I pulled the main filter and drained it into a bucket and there are small fillings in it. I then pulled the case drain filter for the finials and it has quite a bit in it. It was not clogged, but there was alot of metal in it. about 50 hours ago I had serviced the machine and the case drain filter was clean at the time so it must have started pretty recently. It really surprised me since the machine runs great with no noises, doesnt pull to one side, and no power loss.
I am assuming that since the case drain was full of metal my problem lays in the finals and not the pump? I saw a video saying to pull the case drain hose, run the machine and it should just have a small trickle coming from the hose. Anything more than a trickle means problems. I started the machine and at idle not touching the controls, I have a full flow stream coming out from both the right and left case drain hoses.
What is the best way to proceed from here? Since I have so much case drain flow from both motors are both of them shot? Or is there a way to pinpoint which side caused all of the shavings in the filter?
