just got around to that problem again amoungst other leaks and replaced the anticavitation valve that didnt do it so idk but i do appreaciate the help thank you kobe
Hi Mark
Thanks for the update, I'm very sorry that this did not sort the issue. I will look into the manual further to see if there is anything else that I can come up with that could cause the issue. Just need to clarify a couple of things which I should have done earlier in the process. Could you please verify the following if possible.
1) you can raise and lower the boom arms with the foot pedal but you cannot produce any downward pressure?
2)when selecting the bucket positioning button the light does not activate to show it has been selected?
3) does the boom appear to be very slow to come down with full pedal applied for the down function?
4) Can you feel the detent lock position with the boom down foot pedal when pushing the pedal into the float position? Does the boom go into and maintain the float position?
Best regards
