You've spent some money on that T190 Potterx, both drive motors and now a drive pump rebuild. It's one of those things that no one knows just how deep something will get, but once you commit you pretty much have to follow thorough, it happens. Just some advice after you've done all this work, check your hydraulic filter frequently depending on how much you use the machine. The thing about a Bobcat is they're not a true "return to tank" system, they work more on a hydraulic loop system and the reservoir simply keeps the loop full. Additionally, oil in the drive system just loops within the drive system, doesn't go through the main hydraulic filter. Oil going through the loader function valve goes through the hydraulic filter. My point is, oil in a Bobcat doesn't always go through the filter all of the time, but eventually all of the oil does find a route through the filter. Depending on how much you use the machine, let's say you use it everyday, then I'd remove the filter at least once a month after the oil is warmed up a bit. Place your hand over the open end of the filter and agitate the filter. Pour the contents into a clean pan and see how much metal debris comes out. Pour some solvent or diesel in the empty filter and repeat agitation, pour into clean pan again to check debris. Continue this check process to get a feel of when the system is running clean of debris and then service the hydraulic filter according to a normal schedule.
