Bobcat T110
Discussion in 'Mini Skid Steers' started by Chass, Aug 25, 2014.
  1. Chass
    Chass Well-Known Member
    Dec 6, 2013
    65
    Owner small earthmoving & landscape business
    Adelaide South Australian
    Hey all what does everyone think of bobcat T110 just looking on the internet few low hr machine but are listing that it's got new tracks and sprockets the machine have only done between 500hrs and 700hrs:confused:
  2. Chass
    Dec 6, 2013
    65
    My wife thinks 120 views and zero comments is a negative, please comment someone lol
  3. lantraxco
    lantraxco Senior Member
    Jan 1, 2009
    7,698
    Elsewhen
    As a guess I would say lot's of people are interested in the answer to your question (as I am) but have no direct knowledge of this machine. Not negative, just not able to give any helpful answer.
    I will say that if these are ex-rental machines that's about what I would expect, the tracks get torn up and when you put new tracks on to market it out of your rental fleet you get new sprockets as well. Sprockets are cheap for these little guys, tracks maybe not so much, hours on a set of tracks vary tremendously depending on ground conditions, operator ability, and actual type of work done. The tracks are small and go round and round a lot, so they do wear out rather quickly. If that's the only issue, just make sure you look over the rest of the machine carefully for signs of abuse.
    Hopefully you get some feedback from the guys that actually work on or own the T110 soon.
    Cheers :drinkup
  4. crewchief888
    crewchief888 Senior Member
    Feb 2, 2012
    1,664
    NWI
    the few that i've run seem very underpowered.
    but we mainly work on s300's
    :drinkup
  5. bigsmoke
    bigsmoke Active Member
    Aug 22, 2014
    27
    Heavy equipment mechanic
    They are handy, but are a ***** to work on. The engines and hydrostats won't ever let you down, but if you have a fuel tank or fuel pickup issue, the power pack comes out. Not fun.
  6. Chass
    Dec 6, 2013
    65
    Thanks for that bigsmoke. good to know
  7. 245dlc
    245dlc Senior Member
    Mar 16, 2010
    1,228
    Heavy Equipment Operator
    Great for tight spots and the joystick controls make it much nicer to operate and power doesn't seem bad for a smaller machine. Hope that helps. :)
  8. Chass
    Dec 6, 2013
    65
    Thanks for that mate I do like the two speed idea.
  9. SNOWBALL
    SNOWBALL Member
    Sep 4, 2009
    7
    CALGARY, CANADA
    Great machine. Excellent power for the size. You can't compare to the power of an s300
  10. Chass
    Dec 6, 2013
    65
    cheers Snowball I have a Posi track ASV RC30 great machine but the up keep on the under carriage is expensive, performs fantastic. just over the dollars I am putting into this machine. I do like the idea of the 2 speed feature on the T110.
  11. SNOWBALL
    SNOWBALL Member
    Sep 4, 2009
    7
    CALGARY, CANADA
    We put 800 hrs on the 110 in all conditions and the tracks are still more than half left
  12. 4seasons
    4seasons Member
    Jul 29, 2014
    15
    Ny
    I wondered why they only made the 110 for a couple years. Nothing even took it's place size wise. As far as I know there are just two machines in that weight class now. Taki 220 and asv 50.
  13. andersoncol_2
    andersoncol_2 Member
    Feb 23, 2012
    11
    Heavy Duty Mechanic
    Vanscoy, SK
    I have one, and am mostly happy with it. I bought it with about 505 hours on it, and I just hit 630. I changed my tracks today, not because I needed to, but for more traction in the snow. The stock tracks still have lots of life left, just not really aggressive for snow/ice. Called Bobcat today, sprockets are about $290 each. I have the SJC controls with 2 speed. It lifts alot more than you would expect from a small machine and really flies in high range. I do sometimes have some problems turning in mud or heavy dirt. I have pressure tested everything and found all ok. I will chalk it up to SJC control problems. I did find the idle a little low, and the throttle not adjusted to get max spec RPM. Adjusted that up and seems a bit better. It has a full size quick attach, so attachments are plentiful. I have a bobcat 48" snow blower that I use with it and it is amazing how much snow you can move. I also have a 54" pickup sweeper that works well too. All in all, it's a pretty decent machine. The only real repair I had to make was replacing the exhaust flex hose from the engine to the muffler. It's relatively easy to service, and luckily the 500hr service was done at the Bobcat dealer before I bought it. I had an ASV RC30 and it was the worst machine I ever owned. Undercarriage was a nightmare. Seemed like I had to replace things quite often. I didn't even get alot of hours on it before I sold it. It did have a roomy cab with a good heater down by your feet where it is needed. I don't think I'd even look at an ASV again.
  14. Chass
    Dec 6, 2013
    65
    thanks for that I reckon I would get a T110 when the time is right, thanks for the info I do like the 2 speed idea.
  15. Chass
    Dec 6, 2013
    65
    Hi andrsoncol_2 have you still got your T110 and are you still happy with it, I have had enough of this RC30 of mine it has to go, I was thinking of getting the PT30 but after this week ASV and Terex can jam it right up there ass. Can you let me know how it's going please.
    Cheers
    Chris
  16. andersoncol_2
    Feb 23, 2012
    11
    Heavy Duty Mechanic
    Vanscoy, SK
    Hey Chass, I still have the T110, but only up to about 670hrs now. Machine is still running and working well. I have had a few more instances with SJC control issues, but I just shut the machine down and restart it and it goes away. I believe I still have a little warranty on the joysticks, so hopefully it will screw up constantly so I can get it replaced for free. Maybe just need them recalibrated. I bought a hydraulic quick attach kit for it, but haven't had a chance to put it on yet. The design of the machine makes the quick attack lock levers able to contact the loader arm frame when they are unlocked. Can't open my door very far when I have my pallet forks on, but it does have a full size backboard on the forks. I think I'll just cut the backboard down. I run without the door in the summertime, so it's not an issue then. Still no undercarriage issues so far. All in all, I'm still happy with it. I haven't run a T110 with manual controls, so I can't comment on that style. I bought a "Quick Attach Brush Buster Mini Mower" this spring and am looking forward to trying that out too.
  17. Chass
    Dec 6, 2013
    65
    Thanks mate hope it's not a big problem with the SJC controls,thanks again
