I had the engine rebuilt just finished installing and am having engine shutdown to low oil pressure . replaced oil pressure switch and same condition. put a mechanical gauge on and have 56 lbs cold and 30 lbs after its warmed up. The oil pres switch is disconnected from 3 wire connector. Does any one know what to check on I haven't found much info in the shop manual. Thank You
