Dahendo
Well the dealer says the control valve is screwed. Apparently they found scoring in the lift spool bore.
Either that or they also can't figure it out and are taking the replace everything route.
They can't locate a new control valve, I've found a used manual controls valve (SN; 6818039) but I need a ACS valve (SN; 7101354) From what I can see in the pictures, it appears to be the same block with some different fittings and spool ends.
Does anyone know if it is the same block and if the spools are the same so I could part out the two of them and make 1 that works for me?
Pretty sure the previous owner knew what was going on and I'm a sucker!
