Bobcat S175-- error code 05-22 Hydraulic Charge pressure Low
Discussion in 'Skid Steers' started by motochris, Sep 10, 2012.
  1. motochris
    motochris Active Member
    Mar 22, 2012
    36
    Ridgecrest Ca.
    So as posted in another thread... I just picked up a Bobcat S175. It's got a warning light on and giving me a 05-22 error code, saying Hydraulic Charge Pressure is low. The machine works well.... no issues with anything I've used it for. If it does indeed have low pressure... if everything is working fine, am I going to hurt anything to continue using it?
    Searching around the internet for info, I found I should remove the sender and check the actual pressure to figure out if I have an issue or just a bad sender or wiring issue. ... what type of gauge do I use?
    I plan to order service manuals this week... so hopefully I'll be able to answer my own questions soon. ;)
  2. mikebramel
    mikebramel Senior Member
    Jul 15, 2012
    1,612
    milwaukee
  3. motochris
    Mar 22, 2012
    36
    Ridgecrest Ca.
    Ahhh.. just a simple pressure gauge. Cool. Just gotta see if I need to come up with an adaptor to fit the sender threads. Thanks!
    On the pressure note... I'm fairly certain this thing is good on pressure and the issue is a wiring or sender problem. There has been zero problems functionwise with it. It'll lift pallets of shingles to roof height with no issues... leading me to believe it has plenty of pressure. Still gonna double check though.
  4. crewchief888
    crewchief888 Senior Member
    Feb 1, 2012
    1,664
    NWI
    that should be 1/8" pipe.
    if the sender is wet with oil where the harness plugs in the sender is bad.
    :drinkup
  5. murat
    murat Member
    Dec 29, 2017
    12
    moskova
    where to check charging pressure
  6. crewchief888
    Feb 1, 2012
    1,664
    NWI
    remove the charge pressure sender, and connect the gauge to the port, or you can get fancy and connect the guage to a T fitting
    :eek:
  7. murat
    murat Member
    Dec 29, 2017
    12
    moskova
    charge pressure can measure how many bars you need to have
  8. murat
    murat Member
    Dec 29, 2017
    12
    moskova
