Bobcat E32 hard start
Discussion in 'Compact Excavators' started by UpNorth Mini Excavating, Mar 11, 2020.
  1. UpNorth Mini Excavating
    UpNorth Mini Excavating Active Member
    Feb 10, 2018
    29
    Maine
    Hey everyone, so I have a Bobcat E32 mini excavator that starts hard. Im not sure what is wrong with it. Battery is almost new. It cranks really low when it first starts turning like the battery is almost dead and after 7 or 8 cranks it fires up. Now if I put a battery charger on it and crank it will crank faster but still take 7 or 8 cranks before starting. Anyone have any ideas? Now it seems like after I start it the first time, then it fires within a few cranks. I have a bobcat 325G that starts alot better than this E32.
    thanks
  2. Clguest
    Clguest Well-Known Member
    Feb 3, 2016
    98
    USA
    What year is the excavator? How many hours does it have? Are you allowing the preheater to work before you crank the engine?
  3. UpNorth Mini Excavating
    Feb 10, 2018
    29
    Maine
    2013 with 2200 hours. Yes the preheater is counting down.
  4. uffex
    uffex Senior Member
    Jan 23, 2012
    1,519
    Admin
    Lincoln UK
    Good day
    Suggest get the injectors checked out, they can result in a hard start only show up with a initial burst of smoke.
    Kind regards
    Uffex
  5. Bls repair
    Bls repair Senior Member
    Jan 21, 2017
    1,173
    Equipment operator,mechanic
    S E Pa
    What kind of shape is the starter in?
  6. bobcat1
    bobcat1 Well-Known Member
    Nov 13, 2014
    59
    ontario
    Keyless ignition ?
  7. UpNorth Mini Excavating
    Feb 10, 2018
    29
    Maine
    So here is what I did. I went ahead and checked all of my grounds(or so i thought) and replaced my alternator and it was bad. I removed the starter and found there was another ground under the starter that gies to the frame. The connection from the wire to the connector was lose. I installed another connector and will see if that helps once I get finished repacking my cylinders. The starter seems to be in good condition and no it has a keyed ignition. My next step will be taking a look at the injectors if this doesnt work. Thanks
  8. UpNorth Mini Excavating
    Feb 10, 2018
    29
    Maine
    **Update** So after looking around I noticed that I had to much resistance on the ground side with my ohmmeter. I decided to remove the starter and that is where I found the problem. There is a ground that goes from the starter to the counterweight and I noticed the ground wire was very lose in the connector. I installed another connector and put everything back together and it now starts like a champ. Thanks for all the info.
