DirtCrawler
Anyone here that can decipher warning codes for a bobcat CTL?
I think it depends on what instrument panel you have. The machines you start with a key only show you active codes. The machines that you put a code in to start will show you "some" historical codes all the way back to when the machine was new. You have to navigate to that screen, after you have put in the owner code. I say "some" codes, because I will occasionally get an ACS fault when I push the green push to operate button. I turn the machine off and restart and it will clear and everything is fine, but the code is not stored. But, I can see old codes for typical stuff like battery voltage low from before I owned the bobcat.It's been a couple of years now since I've worked on Bobcat machines, but my experience with Bobcat, they don't "store" codes, they only work with "active" (happening right now) codes. If you're machine is spitting out that many active codes you got some really wacky stuff going on with that machine and will most likely need a Bobcat tech to sort it out.
