Bobcat BCIS
Mobilewrench
Kona, hawaii
I am thinking near the hydraulic tank. But I had the tank out of this one in December and don't remember seeing it. Of course I wasn't looking for it then.
Coaldust
North of the 60
Ok, looks like all the BICS functions on this machine are handled by the Gateway controller. It’s too new to have a separate BICS controller.
Might be getting ahead of ourselves. Probably just dealing with a bad seat sensor or door sensor.
Coaldust
North of the 60
I think the deluxe instrument panel provides some BICS troubleshooting functions.
Vetech63
Oklahoma
Since you 2 are the only ones in this thread..........should I leave and give you both more privacy? You forgot to hang a sign n the door! LOL:p
Mobilewrench
Kona, hawaii
No deluxe instrument panel. Just the left side overhead with half of the LCD panel wiped out. And no door, so no door switch. As for the seat sensor; I did not test that. But the park brake does release, it might be that I rarely deal with Bobcats, but I very often deal with cat skid interlock problems. As far as I understand, the only way to unlock the park brake without having someone in the seat is to hit the override button (like if you have a backhoe attachment on it.)
Is the gateway controller the one I found in the parts book (but not yet on the machine)?
Mobilewrench
Kona, hawaii
So far it has been just the two of us high desert Nevada boys. But if you have an idea, I would like to hear it.
Coaldust
North of the 60
Mobilewrench,
I’ll see about locating a pin-out this weekend. I’ve been off-line. Covid is still trying to kill me.
Coaldust
North of the 60
Still broke down? Damn. I forgot what we were talking about. Been off grid for awhile. Have you done anymore troubleshooting on it?
Mobilewrench
Kona, hawaii
Not really. Got next to it yesterday and think that the only code coming up( remember that I can only see either the top or bottom of the lcd screen ) is a code for a hydraulic temp is high. I have a hard time believing that that locks out the interlock.
Mobilewrench
Kona, hawaii
Small.world Nige. Those are the two mines that I worked at. Bald Mountain on a college summer and winter work program and Round Mountain for 7 or 8 years before I moved to Hawaii.
willie59
Knoxville TN
Service Manager
I'm a bit late to the thread. Bobcat T190, that's a G series machine, they didn't use a seat switch, Bobcat tossed those things in the F series machines because they were problematic. G series, those machines have a main controller (ECU) mounted behind the sheet metal panels to the left of your left foot if you were sitting in the seat. The main controller either monitors or controls pretty much everything electrical on that machine. In the cab is another computer mounted inside the BICS panel, the left cab panel, that communicates with the main controller for all cab functions, start/stop, parking brake, warning lights, hour meter, etc. And that left panel is critical on those machines for the main controller to communicate with you, that wiped out hour meter display you have is a problem.
On a G series machine, if all things are working proper, when you first power up the machine, even before you start it, you should hear one long beep from the alarm in the left BICS panel, that's the main controller doing a system test and also lets you know the alarm is working. Once you start the machine, if at any time you hear three short beeps from the alarm, that's the main controller telling you it's seeing a fault and alerting you, that's when you push and hold down the headlight button to check code(s) at the hour meter display. Once you shut off the machine it wipes those codes clean on next start up. If your hour meter display isn't working, or the alarm isn't working, then you've lost that communication with the main controller. The problem you're having, lift/tilt won't unlock, that's a fault that would most definitely cause three short beeps of the alarm on a G series.
I can't recall if the BICS panel is plug and play, but if not I'm pretty sure a Bobcat dealer can provide you with a new one for your machine without much grief. As for the main controller, if you have issues with that, the only persons that can tap in to that main controller is a Bobcat tech as the software to interface with that controller is proprietary to Bobcat techs only.
Mobilewrench
Kona, hawaii
Thanks Willie. I get one long beep and then three short beeps. I am fairly certain that the code is 07-21. High hydraulic oil temp. I am not very hopeful that that is the issue. Been taking care of this machine for a few years now and I seem to remember that code was always active. Do you happen to know where that sensor is? I see two plugs my the filter housing, one two wire the other one wire. I can't remember if there is a sensor on the tank.
There is no longer a dealership on this island. Not even sure if there is one in the state. Been ordering all of my bobcat parts from the mainland for about a year. So I am kind of on my own on this one.
willie59
Knoxville TN
Service Manager
The sensor at the filter with one wire is the differential pressure switch that indicates filter is clogged, the sensor with two wires is the temperature switch. Might also be a sensor in that area with three wires which would be the charge pressure sensor. I've never known a Bobcat that only locks out the lift/tilt valve because of high hyd oil temp, that typically causes engine shut down by the main controller. Lift/tilt lock out is typically other issues and should have codes related to lift/tilt circuit.
