Lynn jackson
New to this. Hope I’m doing it right. Front right axle sprocket weld broke just spins . Question can I remove sprocket without removing are losing axle? I’m in Cleburne Tx anyone know where to get a sprocket. Thanks
Huh?New to this. Hope I’m doing it right. Front right axle sprocket weld broke just spins . Question can I remove sprocket without removing are losing axle? I’m in Cleburne Tx anyone know where to get a sprocket. Thanks
Do you mean the front RH Hub? Or the sprocket inside the chain case.New to this. Hope I’m doing it right. Front right axle sprocket weld broke just spins . Question can I remove sprocket without removing are losing axle? I’m in Cleburne Tx anyone know where to get a sprocket. Thanks
I may have spoken wrong on this one. That model has a one-piece chain case. There is a sprocket retaining bolt on the end of the axle that will need to be removed from inside the chain case. You basically build the axle assembly and slide it through that axle housing. Yes, you will have to remove the axle and it's a pain in the ass.You will have to remove that particular hub assembly
The front ones are pretty easy, still a hard job. The rear once are harder but still not bad.I may have spoken wrong on this one. That model has a one-piece chain case. There is a sprocket retaining bolt on the end of the axle that will need to be removed from inside the chain case. You basically build the axle assembly and slide it through that axle housing. Yes, you will have to remove the axle and it's a pain in the ass.
Thanks you nailed it.I may have spoken wrong on this one. That model has a one-piece chain case. There is a sprocket retaining bolt on the end of the axle that will need to be removed from inside the chain case. You basically build the axle assembly and slide it through that axle housing. Yes, you will have to remove the axle and it's a pain in the ass.
thanksYou will have to remove that particular hub assembly
