Bobcat 863 High Flow Problem
bobcatguy
arizona
Hi all. I picked up an 863 at auction. I cannot engage high flow. Nothing lights up on button. Regular hydraulics work fine. Any idea what to look for?
jacobd
North carolina
Are you sure it's equipped with high flow hydraulics? Lift the cab and look at the gear pump. If high flow it will have two outlets as opposed to just one outlet for low flow.
jacobd
North carolina
I believe that is a high flow pump so you're good there. It's probably just an electrical problem. Hold down the headlight button and tell us what codes flash on the hour meter. Also just to be clear, with the standard auxiliary hydraulics activated and functional nothing happens when you press the button for high flow?
jacobd
North carolina
Behind the access cover on the left hand side under the loader arm you should find a valve block that looks like the picture. #4 is the high flow solenoid. It must be activated for high flow to function. Check for voltage there when the high flow is engaged.
What is the serial number of your machine?
bobcatguy
arizona
I have no power going to the connection at #4 with or without highflow button pushed. Had to remove the front steering arm panel to access and in doing so had to disconnect several wiring harness connections. Not sure if any of those are related to the high flow circuit.
