bobcat 843 hydraulic oil and engine oil question
Discussion in 'Skid Steers' started by brennandc, Dec 19, 2012.
  1. brennandc
    brennandc New Member
    Dec 19, 2012
    4
    MN
    The service manual for my (1988) 843 bobcat says you can use 5W30 motor oil for hydraulic fluid. So my question is, it OK to use a full synthetic or synthetic blend of this oil? What would any pros or cons be? Also, I can't seem to find what type of oil is spec-ed for the ISUZU engine (54 HP 4 cylinder) Anyone know? Thanks!
  2. Bobcatdan
    Bobcatdan Well-Known Member
    May 16, 2012
    241
    wisconsin
    15w40 in the engine. As the hydraulic, bobcat use to say 10w30 could be used in a case of emergncy, but always pushed the use as bobcat hydraulic/ hydrostatic. I know plenty of farms that solely run 10w30 with no problems. I don't think there would be any gain in running synthetic in the hydraulic
  3. firedude26
    firedude26 Active Member
    Dec 23, 2010
    35
    se mich
    my manual for my 743b says 10w30 in hyd, only advantage i see for using syn in hyd is if you was in a cold climate. i used syn in crank case that helps alot on cold starts. i need to add hyd fluid to it and was wondering samething, since i bought it used im not sure what is actually in it.
  4. crewchief888
    crewchief888 Senior Member
    Feb 2, 2012
    1,657
    NWI
    as of 2006 bobcat no longer recommends engine oil in the hyd/hydrostatic system.
    engine oil formulas have drastically changed over the years, as have some hyd oil formulas
    :drinkup
  5. firedude26
    Dec 23, 2010
    35
    se mich
    so reg hyd fluid is used now? or is there a special kind of hyd fluid? i wanna change the fluid and filter in this machine, just so i know whats in it.
  6. willie59
    willie59 Super Moderator
    Dec 21, 2008
    12,275
    Service Manager
    Knoxville TN
    A good quality AW hyd oil will work fine. Being in SE Michigan, might want to use AW32.
  7. crewchief888
    Feb 2, 2012
    1,657
    NWI
    bocat hyd oil, along with bobcat filters is all i can recommend
    :drinkup
