James Clark
I have a 1999 bobcat 773f series, once my engine is warmed up the rpms drop off under load then even just running around and the unit will hardly run. It will even die sometimes. I've replaced all fuel lines and primer bulb, fuel filter.
I read one thread that said if i could use the primer bulb to keep the rpms up then i should change the pickup pump, needless to say it didn't solve my issue. I also have installed a clear fuel filter in the fuel line in front of the primer bulb.
So i think i'm going to hook a gal. jug straight to the primer bulb and see it that makes a difference, if it helps then i can assume that the fuel pick up line is my issue ?
Any one have any other ideas as to what i should do.
thanks for any ideas james
