Scott Bare
I have recently replaced the lift and tilt actuators and replaced the spool seals. When I hooked everything back up I filled up the hydraulic oil and started the machine I can hear a hissing sound as if my valve is being used and my tilt fully extended lifting the front of the unit by itself. There is no sound or movement when I use the lift/tilt function. I replaced the valve solenoid with no luck. I am getting a 1 blink, on my BICS panel. Can’t seem to figure out why I am not able to make it work.
