Tbobinac
Hello, We were running our bobcat 753 s/n 515843577 most of morning. Went to get another load of dirt with truck, came back machine turned on but bucket would not move. Looked at light panel, the tilt/lift light is not on. Checked, no codes showing up. The machine moves around but the bucket does not lift or tilt. I can move the pedals if i push on them really hard, so I am guessing something electrical...
I can't seem to find what the problem is to be able to fix. Someone suggested the BICS, we just put a new one in January, don;t think I need a new one so soon. Someone else suggested the solenoid, I changed that this weekend still no light. Please note when I went to change the solenoid, the cab was really loose to the frame (bolts were worn out), I put new bolts in and made sure it was tighten down. Also I did check the fuse, looked fine but I put a new one in just to try, but still no light.
I don't mind ordering another BICS if that is what you think, but wondering why I am going through one so quick?
