bobcat 743 lost all hyd movement
Discussion in 'Skid Steers' started by firedude26, Jun 27, 2019.
  1. firedude26
    firedude26 Active Member
    Dec 23, 2010
    35
    se mich
    i was grading driveway and went from reverse to forward and all controls just quit working, no lift or tilt no forward backward, there was a ticking kinda noise , not sure what went wrong or how to test , im thinking the hyd pump took a crap. any help would be great. i just replaced the motor, and there was a small leak coming from the pump, not bad though, and it didnt dump any fluid out when it stopped.
    thanks
  2. Ronsii
    Ronsii Senior Member
    Jun 26, 2011
    3,544
    s/e Heavy equipment operator
    Western Washington
    You might have spun the splined shaft from the motor...
  3. willie59
    willie59 Super Moderator
    Dec 21, 2008
    12,486
    Service Manager
    Knoxville TN
    Yep, the 743 had a U joint connection between motor and pumps, that's the first place I'd look
    Vetech63 likes this.
  4. Vetech63
    Vetech63 Senior Member
    Aug 10, 2016
    2,294
    Oklahoma
    What Willie said ^^^*
  5. firedude26
    Dec 23, 2010
    35
    se mich
    i just put motor back in it, and the joint seemed fine. i ran it for probly 2 hours or so since.
    i greased it up and all, whats the easiest way to check that with out pulling radiator out of the way?
  6. Vetech63
    Aug 10, 2016
    2,294
    Oklahoma
    It usually strips the splines on either the coupler or the pump shaft. From above it will look normal even if it is stripped internally.
    Ronsii likes this.
  7. Ronsii
    Jun 26, 2011
    3,544
    Western Washington
    could be it broke a shaft somewhere.... cause if you lost ALL hydraulics - lift/tilt and machine movment then that would indicate engine power is not getting to the hystat drive
    firedude26 likes this.
  8. firedude26
    Dec 23, 2010
    35
    se mich
    i guess we will have to pull motor again, UGH this thing is killing me, let me ask this, the hyd pump is leaking anyway, do u pull that all out from the front? might be easier or make more sense to pull it out and check it all and have pump fixed
  9. Ronsii
    Jun 26, 2011
    3,544
    Western Washington
    More than likely like Vetech said with the worn splines... happens on lots of different equipment, usually at the pump shaft.
  10. willie59
    Dec 21, 2008
    12,486
    Service Manager
    Knoxville TN
    I have to admit it was like last century when I worked on 743's, and someone can correct me if I'm wrong, but seems I recall one can service that u-joint connection without removing the engine, but I'm not real certain about that.
  11. Vetech63
    Aug 10, 2016
    2,294
    Oklahoma
    You have to pull the engine or the pump. The engine removal is quicker and cleaner. You can grease it by performing a 4 ft long arm reach around. LOL
    mikebramel and firedude26 like this.
  12. firedude26
    Dec 23, 2010
    35
    se mich
    i just swapped the 1702 with a 2203 maybe the new power stripped it out, lol i really need to pull the pump and have it rebuilt, anyone in SE MI wannna job???
  13. Vetech63
    Aug 10, 2016
    2,294
    Oklahoma
    Those splines wear quickly and most people won’t even notice how bad they are worn unless they have experienced the problem before.
  14. Vetech63
    Aug 10, 2016
    2,294
    Oklahoma
    You may want to pull the pump since it is leaking anyway. The good thing is by doing so, you already have it out if you need to replace the driven shaft. You can get to the coupler bolts on the flywheel also. If you pull the engine and find your pump splines bad, then you end up pulling both when it isn’t necessary.
    firedude26 and mikebramel like this.
  15. firedude26
    Dec 23, 2010
    35
    se mich
    i was just reading to where there is a seal behind the spline on the pump, that maybe where my leak is, the forum said you can replace the spline and seal with it in machine??
  16. Vetech63
    Aug 10, 2016
    2,294
    Oklahoma
    The seal you can replace as it is an external seal with a snap ring retainer. The female coupler on the flywheel you can change out with either the pump or engine removed. If you need a pump shaft, I always build those vertically on a stand.
  17. firedude26
    Dec 23, 2010
    35
    se mich
    so since in not able to do the work, would it be easier to pull the pump or motor? i cant find any you tubes on removing the pump
  18. Ronsii
    Jun 26, 2011
    3,544
    Western Washington
    Pulling the pumps is pretty straight forward, just lift the cab, remove the linkages, undo all hoses/tubes to the pumps and unbolt it.. :) there are probably a couple little things I forgot it's been 25 years since I pulled one ;) but it's not brain surgery.
  19. firedude26
    Dec 23, 2010
    35
    se mich
    ok ill ask the guy thats gonna do the work for me what he wants to do, i just had shoilder surgery yesterday so im out if commision for a few months for the heavy stuff
  20. firedude26
    Dec 23, 2010
    35
    se mich
    OK UPDATE, just pulled motor , the bolt that holds the spline on the Hydro pump backed off and that was it????? i have a new spline, and yoke ordered, there really isnt any wear on either, i have them soaking now in parts cleaner, i cant believe that this happened im happy that it wasnt worse but i am going to change the seal so nom more leaks. the new parts are $450 im noit sure i wanna pay that or just use what i have???? also the dealer said this job would be 20 hours plus parts, i think they are screwing anybody, took motor out in 1 hour flat and that included BS time.
